Superformance pan gasket ?? #3131589
03/22/23 10:52 PM
03/22/23 10:52 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Using superformance pan gaskets between the pan, windage tray and block. Do these require a sealant ??
Re: Superformance pan gasket ?? [Re: Stanton] #3131596
03/22/23 11:43 PM
03/22/23 11:43 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I use clear silicone sealer, just a light coat. No leaky
Re: Superformance pan gasket ?? [Re: Stanton] #3131601
03/23/23 12:46 AM
03/23/23 12:46 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
I use a thin coat of Ultra black, excellent gaskets, no leaks.
America First!
Re: Superformance pan gasket ?? [Re: carnut68] #3131613
03/23/23 08:43 AM
03/23/23 08:43 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The reason I ask ... silicone these in probably six or seven years ago and then the motor has just been sitting. Took the pan, etc off last night to check something and expected a real battle to get things unstuck. Pushed an Olfa blade between the block and gasket and it went in like there was nothing there. Ran it around the whole rail with no resistance. When I pulled everything apart there is nothing stuck to the gaskets.
Now they say "Non Stick designation has an easy release coating on both faces ..." . Yes, so easy nothing sticks to it ! So I'm wondering if there is any point in using a sealant.
Re: Superformance pan gasket ?? [Re: Stanton] #3131722
03/23/23 03:12 PM
03/23/23 03:12 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Be careful whenever using RTV silicone... its the most abused and over-used chemical in the industry. It should most commonly be used as a filler of gap, such as corner intersecting joints (oil pans, intake manifolds/end seals).
IF the gasket supplier specifically indicates NOT to use silicone, then don't use it. Typically, RTV silicone is a mess to clean up as well as to release the gaskets IF previously applied over them. Also, IF any excessive RTV silicone falls inside the engine, it can eventually clog the oil pick-up screen, oil and/or water passages, etc. The gaskets do the sealing... not the chemical (unless there is gap to be filled).
I'm a former Applications Engineer for a major gasket company... and I wrote most of the instructions within their sets.
Re: Superformance pan gasket ?? [Re: Mopar Mitch] #3131772
03/23/23 07:12 PM
03/23/23 07:12 PM
PA
moparacer Offline
moparacer  Offline
PA
I run them dry, and use them over and over and over with a Milodon pan.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Superformance pan gasket ?? [Re: moparacer] #3131791
03/23/23 08:35 PM
03/23/23 08:35 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Dry as well, no issues.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
