Page 3 of 3 1 2 3
Re: Race engine oil viscosity [Re: RapidusMaximus] #3131494
03/22/23 05:05 PM
03/22/23 05:05 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
As mentioned, it is all about how your engine is setup. Old school loose clearances thick oil. One main reason for the loose clearances is a stock block was designed for what, 400HP and we build them to 700HP the block moves around during hard loads. Loose clearances absorb this deflection. I use 20W50 VR1 for years in my race car. Modern engine good stiff block tighter clearances 10W 30 or thinner. Almost all of my builds for street engines get 10w30 Lot of hydraulic roller lifters now will not work correctly with oil thicker than 10w30.
Re: Race engine oil viscosity [Re: moparx] #3131570
03/22/23 09:43 PM
03/22/23 09:43 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Originally Posted by moparx
when you say the oils are better today than back then, does that mean the pennzoil 60wt racing oil in the cardboard cans i have is not to be used ? biggrin
beer
Maybe in blown alcohol or fuel, or an old shovelhead.
Re: Race engine oil viscosity [Re: CMcAllister] #3131756
03/23/23 06:12 PM
03/23/23 06:12 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I run 5W-20 when index racing (B-Gas) and I run 0W when running N/A 10.5. I use Maxima Racing oils and have had awesome luck with it.
Re: Race engine oil viscosity [Re: Biginchmopar] #3131760
03/23/23 06:17 PM
03/23/23 06:17 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Goodness gracious that’s a beautiful car up Are you on methanol or gas?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Race engine oil viscosity [Re: RapidusMaximus] #3131762
03/23/23 06:18 PM
03/23/23 06:18 PM
Carson City, Nevada
Carson City, Nevada
Gas
Re: Race engine oil viscosity [Re: RapidusMaximus] #3132370
03/26/23 07:25 AM
03/26/23 07:25 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
https://drivenracingoil.com/rt-5996-catalog.html
Download the catalog and find their chart on viscosity recommendations. I attached a photo as well. The section on viscosity recommendation also explains about running alcohol and how to choose a viscosity right for your engine.
Re: Race engine oil viscosity [Re: 71Demon528] #3132625
03/27/23 09:16 AM
03/27/23 09:16 AM
PA
moparacer Offline
moparacer  Offline
PA
I am not anywhere near as smart as they are but the best way to deal with fuel dilution on a E85 or Alky setup is #1 work on your tune so it doesn't milk the oil, #2 run the proper crankcase evacuation AKA a vac pump so what moisture is created is removed and #3 run your engine hot enough to help with evaporation of the moisture so the pump can remove it. twocents
Nothing good ever comes from diluted oil.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Race engine oil viscosity [Re: moparacer] #3133491
03/29/23 09:03 PM
03/29/23 09:03 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I have been using 20W 50 and I believe that is why I am wearing down my bronze gear so quickly
I plan on switching to 10w30
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Page 3 of 3 1 2 3
