Re: Dodge Demon 170 reveal
[Re: hotairballoonpilot]
#3131503
03/22/23 05:34 PM
03/22/23 05:34 PM
Posts: 1,270 Nor here, Nor there
Dart 500
Nor here, Nor there
when it was flown in it did not have the parachute on but either they went behind the wall and installed it quick or there were 2 cars on site. 2 cars for sure, the heli one had a good chance of falling off
[Re: Dart 500]
#3131536
03/22/23 08:08 PM
03/22/23 08:08 PM
Posts: 10,502 Chicago, Illinois
Devil
Chicago, Illinois
Let me answer some of the questions that is out there. The Helicopter guy was like a surgeon. We were amazed! It went right over my head! The 8.91 was legit there at the track, there was people I know in the timing tower that saw it go down. They can't use the pitchfork demon logo because I believe yearone or someone bought the rights to the character when Dodge let it lapse. The car with the parachute is the same one that came in on the Chopper. They brought it down the track, behind the tower, mounted the parachute and came back out. There was three on display at the event, all are accounted for.
[Re: Devil]
#3131694
03/23/23 01:30 PM
03/23/23 01:30 PM
Posts: 946 Carlisle, PA
cudaboy340
Carlisle, PA
Ryan, what/where was the 3rd one. There was the one on the track and the one in the Dodge VIP area - both were silver. I didn't see a third. The one in the Dodge VIP area was missing the parachute but it had the "Alcohol Injected" logo on the hood scoop. The one on track did not have the logo. The one on the track had a fairly stripped interior while the one in the VIP area had the full interior with the cool logo embossed in the seats! Either way, it's always great to see you!! Ed
[Re: cudaboy340]
#3131710
03/23/23 02:39 PM
03/23/23 02:39 PM
Devil
Chicago, Illinois
Ryan, what/where was the 3rd one. There was the one on the track and the one in the Dodge VIP area - both were silver. I didn't see a third. The one in the Dodge VIP area was missing the parachute but it had the "Alcohol Injected" logo on the hood scoop. The one on track did not have the logo. The one on the track had a fairly stripped interior while the one in the VIP area had the full interior with the cool logo embossed in the seats! Either way, it's always great to see you!! Ed It was good seeing you as well. The third one was outside the Dodge VIP area sorta. By the time I came back around it was covered up.
[Re: 318 Stroker]
#3131739
03/23/23 04:15 PM
03/23/23 04:15 PM
Posts: 10,989 Nort Cackalacky
rrbrucea
Member known as the "Artist"
Nort Cackalacky
What is the meaning of the 170 designation? Also, it's interesting that the car has the widebody rear fender flares, but not the fronts. It's 170-proof grain alcohol that maximizes the HP rating to that insane 1025. They're running drag radials on the back, so they have the wide body fenders there, but they have relatively "skinny" front runners, so no need for the wide-body flares in front.
[Re: rrbrucea]
#3131755
03/23/23 05:59 PM
03/23/23 05:59 PM
Posts: 12,351 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And I like that look better than having the flairs both front and rear. Wides on the rear and stock width fronts. Kinda 70s chic.
Master, again and still
[Re: Dart 500]
#3131859
03/24/23 10:08 AM
03/24/23 10:08 AM
Posts: 4,715 Wichita
GY3
Wichita
It will be if that ET can't be replicated like the demons 9.65 couldn't. 9.30's-9.40s is probably what it'll run and you'll have to know what you're doing to do it People that race understand prep, DA, water grains and the limitations of a factory delivered suspension. The numbers are when everything is optimized and you pull off a perfect pass. I have lots of passes in the 10.20's and only one that is 10.01. Radial prep lately is the biggest issue.
[Re: GY3]
#3131924
03/24/23 01:58 PM
03/24/23 01:58 PM
Dart 500
Nor here, Nor there
It will be if that ET can't be replicated like the demons 9.65 couldn't. 9.30's-9.40s is probably what it'll run and you'll have to know what you're doing to do it People that race understand prep, DA, water grains and the limitations of a factory delivered suspension. The numbers are when everything is optimized and you pull off a perfect pass. I have lots of passes in the 10.20's and only one that is 10.01. Radial prep lately is the biggest issue. I hear you but they had a demon only event in the winter with a fully prepped track and still not one of the cars hit the 9.65 ET.
[Re: massdaytona]
#3134170
04/01/23 01:38 PM
04/01/23 01:38 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
Thx for that, never knew they are fudging the 0-60 what is the 0-60?? The Engineering Explained YouTube channel accuses Dodge of stretching the facts by quoting the Demon 170's 0-to-60-miles-per-hour time at 1.66 seconds because the figure includes a rollout,
