Re: gas guage sending unit.
[Re: bonefish]
#3130804
03/20/23 12:27 PM
03/20/23 12:27 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
mancini and classic are once again offering units,anyone tried one,if so are the good? Dunno, but if you find a good source, PLEASE let us know. There is a Company called Tanks INC. that sells a "meter match that works very well for the repop garbage sending units METER MATCH LINKY
[Re: TJP]
#3131005
03/21/23 07:22 AM
03/21/23 07:22 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
.. .....Thanks that looks like the ticket, i need to buy a gauge anyway so ill letcha know how close it is
[Re: EW1BH27]
#3131085
03/21/23 12:15 PM
03/21/23 12:15 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I swear by this mod that I learned about here on Moparts years ago. I'll never install a new sending unit without adding the wire first. I added the text to the picture. Very interesting and good to know. I will definitely try that next time. Thanks
[Re: IMGTX]
#3131193
03/21/23 06:40 PM
03/21/23 06:40 PM
Posts: 215 Findlay
Ramman
Findlay
4 My original unit had a crusty ground clamp/strap from the sender outlet to the body mounted fuel line. I replaced it with a reproduction piece from Summit. https://www.summitracing.com/parts/OER-MF290
[Re: TJP]
#3131195
03/21/23 06:56 PM
03/21/23 06:56 PM
Posts: 143 Canada
EW1BH27
Canada
I swear by this mod that I learned about here on Moparts years ago. I'll never install a new sending unit without adding the wire first. I added the text to the picture. Did your units work correctly with the wire and no other changes ? Yes and No. They did, electrically. The float arm on one still needs to be bent. When the gauge reads empty I still have 1/8 of a tank of gas in it. I fixed an original A body sending unit for a friend that I videoed showing how bad the ground was before the wire and steady after the wire. https://www.youtube.com/watch?v=gV_HMJa5maYhttps://www.youtube.com/watch?v=x5m71Tes0n0
[Re: EW1BH27]
#3131249
03/21/23 09:15 PM
03/21/23 09:15 PM
Posts: 1,754 Phila
PhillyRag
Phila
I swear by this mod that I learned about here on Moparts years ago. I'll never install a new sending unit without adding the wire first. I added the text to the picture. Did your units work correctly with the wire and no other changes ? Yes and No. They did, electrically. The float arm on one still needs to be bent. When the gauge reads empty I still have 1/8 of a tank of gas in it. I fixed an original A body sending unit for a friend that I videoed showing how bad the ground was before the wire and steady after the wire. https://www.youtube.com/watch?v=gV_HMJa5maYhttps://www.youtube.com/watch?v=x5m71Tes0n0 That's not all that bad. Kind of like a safety issue: i.e. margin for error. Like the lights they have on modern cars, when 2 or glns left til empty. And who cares if a full tank reads a smigg'in above/below the F mark. It's not you're going to calculate your mpg per these gauges.
