CAMS #3130243
03/17/23 10:42 PM
03/17/23 10:42 PM
Shelby mi.
JAKE68 Offline OP
JAKE68  Offline OP
Shelby mi.
We have been running this motor combo for about 8 seasons, It is a 572 with 572-13 heads ported by the late jeff k from modern,it has 2 800 edelbrocks on indy crossram, 15.4 comp, made 983@7000 and 817 tq@5500. Car is a 9.00@148 @3650 lbs 4.30 gear 10.5x31w. Last year we broke a lifter and damaged the cam. We have another cam on the shelf and thinking of using it as to not having to buy another new one since cores also are a problem. here are the specs for the cams. first the damaged cam 278/290 .480 .480 113 ls inst@109. The cam on the shelf is 283/300 ,496 .471 115 ls inst @113. We have both 1.6 rockers and 1.7 rockers to use. Also we run it on q16 fuel. What are your thoughts on that cam change .Thanks jake
JAKES AUTOMOTIVE
Re: CAMS [Re: JAKE68] #3130244
03/17/23 10:50 PM
03/17/23 10:50 PM
AndyF Offline
AndyF  Offline
If the lobe family is the same then it shouldn't be much of a change. If the lobe family is different then you might see an improvement or perhaps a problem. The additional intake lift might cause you an issue so you'll need to double check that for sure. I've done a lot of cam testing and what I've learned is that it is almost impossible to guess what a slightly different cam will do in an engine. The interaction between the intake runners, head porting, exhaust system and the cam lobe is too complex to fully understand.
Re: CAMS [Re: AndyF] #3130279
03/18/23 09:27 AM
03/18/23 09:27 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Yep sometimes you never know. A good engine simulation with good info imputed is the best bet to try and understand what will happen. And I don't just look at max HP and Torque, I look at average HP and Torque, predicted cylinder pressure, volumetric efficiency, and where it happens at.
Re: CAMS [Re: jwb123] #3130712
03/20/23 12:00 AM
03/20/23 12:00 AM
BigFish69 Offline
BigFish69  Offline
Gary can't you have the lobe fixed and reground
Re: CAMS [Re: BigFish69] #3130729
03/20/23 07:55 AM
03/20/23 07:55 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Respectfully, I think that's a change that will be noticeable. Obviously it might require new support valvegear. It made GOOD power with the old cam, I might regrind the new one. I have a 'spare' 55mm 4/7 swap 114lsa that is in between but still has .480 lobes...
Re: CAMS [Re: HardcoreB] #3131761
03/23/23 06:17 PM
03/23/23 06:17 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Second cam spec sounds real familiar. I would think it would pick up a lil power with the second cam.
