Re: rebuilding 06 5.7
[Re: chrisf]
#3130580
03/19/23 03:10 PM
03/19/23 03:10 PM
Posts: 1,552 Michigan
Kiddart
I think you would need to change front cover assembly due to hood clearance and the intake.
Thank you Kiddart
[Re: Kiddart]
#3130628
03/19/23 06:33 PM
03/19/23 06:33 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
I think you would need to change front cover assembly due to hood clearance and the intake. thanks for the reply. i would hopefully use all my 06 car front drive stuff and a eagle intake if everything works together.
[Re: chrisf]
#3130658
03/19/23 08:24 PM
03/19/23 08:24 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
i have a 06 300. its a 5.7 heritage so a bit better than just a stock "C" i would like to keep the car so thinking of rebuilding and adding some useable power. thinking maybe a 392 stroker. question. i have access to a 16 5.7 truck engine that is super low mile (10k-ish) would that be a better start? i would think tone ring is an issue but anything else?. (buy the 32 tone ring crank?) is that a good swap or stick with the earlier engine? nothing stupid for power 475-ish Wouldn't it be easier to just drop a used 6.4 in? Ask Dave
[Re: wheelsup68dart]
#3134112
04/01/23 09:20 AM
04/01/23 09:20 AM
Posts: 885 south louisiana
lowell66dart
south louisiana
I'm stacking parts now for something similar on my 2007 Charger. I have a set of Eagles with new springs, valves, guides and valve job ready to go. Also have SRT shorties and cat delete pipes. Picked up the cam yesterday. Still need lifters, Cometic head gaskets, timing chain, oil pump and measure for pushrods when the new heads go on. I also have a 392 manifold that I may use. I am using a Diablo tuner. Already have the rear cats and EGR deleted.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
