end of post
#3130468
03/19/23 07:38 AM
03/19/23 07:38 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Thanks in advance to all. Thanks Moparts
Re: Cooling issue
[Re: terzmo]
#3130469
03/19/23 07:52 AM
03/19/23 07:52 AM
Posts: 5,829 ohio
ruderunner
ohio
I'd Look first at getting a good shroud. Your primary issue is inadequate airflow.
This can be confirmed with even a cheap fan zip tied to the radiator. If it cools down at idle when you turn the fan on, there you go.
Angry white pureblood male
Re: Cooling issue
[Re: ruderunner]
#3130473
03/19/23 08:38 AM
03/19/23 08:38 AM
Posts: 10,570 Freeport IL USA
poorboy
Freeport IL USA
On my 49 Dodge truck, I had to remove the factory motor driven fan because there wasn't enough clearance between the radiator and the water pump (you get that with putting a V8 and different chassis under old sheet metal).
My local Car Quest had a high CFM single 16" electric fan that has adjustable temp settings for the cooling speed settings. I bought the 16" fan because it fit the vary tight confines of the location it had to fit in and matched the height of my very small 4 core core Champion radiator. There is a temp range between the turn on and the turn off you can't adjust, but you can choose the high/low range of the operating temp. The fan comes in a kit with the fan, temp control thermostat, and a wiring kit. Its attached to the radiator with those radiator zip tie things and there are a few choices on how to mount the temp probe for the thermostat. This system has been on the truck for a couple of summers now and seems to be working well. You will need to make a shroud for it to work on your radiator, or there could be larger diameter fans (or a dual fan) system available. My point is, adjustable temp electric fan kits are out there. When mine kicks on, you can watch the temp drop on the temp gauge. It only runs a minute or two when the coolant temp hits your high temp range, and shuts off when it reaches the low temp setting. I have mine is wired through the ignition switch so it only runs when the motor runs, but it can be set up to come on ( and turns off) when ever the temp limits are hit.
With that said, making a very good fan shroud for your existing system may actually solve your cooling system problems. You really need to pull as much air through your radiator at idle speed as you can, and your current half azz shroud isn't doing the job. If the good shroud doesn't solve your issue, you can then simply buy the adjustable electric fan to replace your existing fan size.
Re: Cooling issue
[Re: terzmo]
#3130486
03/19/23 10:02 AM
03/19/23 10:02 AM
RapidRobert
I'm wondering if a smaller pump pulley to speed up the air/water flow would be a solution
Re: Cooling issue
[Re: terzmo]
#3130495
03/19/23 10:53 AM
03/19/23 10:53 AM
Posts: 12,092 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Most agree that air flow is the issue. Having been in this position before, I'll offer a suggestion that has worked for me; I go to a pick-a-part yard and pull a fan from an 80s Dodge pick up. It is too large in diameter to fit in the shroud. But, it's aluminum so it's easy to cut down, is lighter than the steel fan you have now, and it's balance isn't hurt much with the trimming.
Those fans move a LOT of air. More blades and more pitch to boot so it gets a clutch due to the additional drag. I have used this on several Mopars with no down side. Currently I have one on the 540 Hemi in my Cuda and it still has the original re-cored radiator with a good shroud.
And, if it matters, this route is cheap.
Master, again and still
Re: Cooling issue
[Re: DaveRS23]
#3130511
03/19/23 11:41 AM
03/19/23 11:41 AM
Posts: 4,730 Florida
BDW
Got a pic of this?
Re: Cooling issue
[Re: BDW]
#3130514
03/19/23 11:45 AM
03/19/23 11:45 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'm not good at posting pics, but I'll try.
Re: Cooling issue
[Re: topside]
#3130627
03/19/23 06:03 PM
03/19/23 06:03 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have the opposite problem in my stockish 67 383 Coronet. Runs hot on highway and cools off as soon as I slow down.
Re: Cooling issue
[Re: markz528]
#3130662
03/19/23 08:36 PM
03/19/23 08:36 PM
RapidRobert
I have the opposite problem in my stockish 67 383 Coronet. Runs hot on highway and cools off as soon as I slow down. needs more radiator (or current one rodded out)
Re: Cooling issue
[Re: RapidRobert]
#3130672
03/19/23 09:13 PM
03/19/23 09:13 PM
Andrewh
I have the opposite problem in my stockish 67 383 Coronet. Runs hot on highway and cools off as soon as I slow down. needs more radiator (or current one rodded out) or you have an airflow blockage at higher speeds, or you have a colapsing lower hose at speed.
