Any tips on freeing up a tight B-body lower control arm?
#3130032
03/17/23 12:50 AM
03/17/23 12:50 AM
Posts: 859 VA
AtomicDog
VA
I have some '70 B-body lower control arms and after pressing in the new lower control arm bushings, the pivots (where the torsion bar slides into the back of the arm and the adjuster arm moves up and down) are very tight and nearly impossible to move by hand. Are there common ways to free them up so that the arm pivots freely again?
Re: Any tips on freeing up a tight B-body lower control arm?
[Re: Greentween]
#3130085
03/17/23 10:26 AM
03/17/23 10:26 AM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
"after pressing in the new lower control arm bushings"
Sounds like they were free before you pressed in the bushings and now they are tight? If so they were not supported properly when the bushings were pressed in and got bent. I agree. However when installed and adjusted the pivot does not move in relation to the arm. It only moves when making adjustments. If the bend isn't effecting the arm's geometry but the weight of the car can move the adjuster you can still use them. I have seen them really tight and still work fine.
[Re: AtomicDog]
#3130142
03/17/23 02:02 PM
03/17/23 02:02 PM
Posts: 1,238 Chicago, IL
PLUM_72
Chicago, IL
The YouTube video below is pretty interesting. He fixes loose lower control slop, but I imagine the same techniques can be done for fixing ones that are too tight. https://youtu.be/Nwes-SP8u4w
1972 Dodge Challenger
[Re: AtomicDog]
#3130268
03/18/23 07:49 AM
03/18/23 07:49 AM
Posts: 5,924 ohio
ruderunner
ohio
IMHO, tight is better. It would have to be pretty much seized to cause any problems. The weight of the car will make it move.
Angry white pureblood male
