Re: Slow Progress at Zippy Performance
[Re: ZIPPY]
#3129792
03/16/23 02:22 AM
03/16/23 02:22 AM
Posts: 1,505 TN
SCATPACK 1
TN
Nice work Zippy I am enjoying following along.
Old Geezer Racing
[Re: SCATPACK 1]
#3129980
03/16/23 08:03 PM
03/16/23 08:03 PM
Posts: 17,842 S.E. Michigan
ZIPPY
S.E. Michigan
Cool 👍
The lighting was just right to flop the color to green about as strongly As I ever gets, and This work really is a pretty big leap forward, so I had to take another pic.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3130029
03/16/23 11:55 PM
03/16/23 11:55 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Looks really outstanding! Nice work. Forgive me if it was stated…..I looked back but maybe missed it: what A4 did you go with? PPG, RM? Etc. a few years ago, the paint shop had a difficult time with the orig AA1 (for 1968) and we ended up with RM brand.
[Re: Chargerfan68]
#3130077
03/17/23 10:12 AM
03/17/23 10:12 AM
ZIPPY
S.E. Michigan
I went with PPG, color code #2016.
thanks for the compliment, it's been a long journey to say the least.
Rich H.
Esse Quam Videri
[Re: n20mstr]
#3131049
03/21/23 10:29 AM
03/21/23 10:29 AM
ZIPPY
S.E. Michigan
Thank you guys again. It'll probably get a stock type trunk mat to avoid scratches.
I usually haul around a bunch of stuff back there so I have to do somethin'......
It's really a big car, I've got comments from folks on arm length before, so it must be true. Arm+torso combined and sufficient core strength to lean way in there seems to be what it's about.
I've picked and sanded a few colored fibers out of the paint here and there, and just got a couple moon suits from Amazon to help with that problem.
Considered calling around to see if I can rent a booth, but not sure I want to deal with the pressure of getting in and out quick....so will probably start hanging plastic and tarps pretty soon. Need sufficient time to repair inevitable mistakes and so on.
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3131315
03/22/23 06:03 AM
03/22/23 06:03 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
It’s all coming along nicely, Rich!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3134771
04/03/23 01:57 PM
04/03/23 01:57 PM
ZIPPY
S.E. Michigan
Just a little update with more color.
Coming along slowly but surely.
Fly masked and back taped everywhere for soft edges, but am also expecting to have to lightly sand the edges here and there.
Will probably prep the ridiculously heavy steel hood just to have the car complete and to be able to paint all the parts, but to be honest I probably won't even use it.
Shop is a gigantic mess and I need to regroup before taking too many more steps.
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3134804
04/03/23 03:20 PM
04/03/23 03:20 PM
Posts: 4,675 On the parachute mount
n20mstr
I would paint that car apart, that avoids the "tape lines in the jambs etc. I know its silver, but just position the doors, fenders etc as they would sit on the car. Then just be accurate in your gun and air pressure settings. Same number of coats etc. I have done this countless times and the cars have all matched, and look great. HOWEVER.... i have recommended this procedure to some people and for some reason they have had color match issues... MAYBE im just lucky?? it hasnt bit me yet. I love doing the main shell first, then hanging the parts on it as i paint them... WhaTEVER YOU ARE MOST comfortable with is what you should do. Looks great so far
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3134877
04/03/23 07:42 PM
04/03/23 07:42 PM
ZIPPY
S.E. Michigan
I love to panel paint, I did consider it and might try it if it was a solid, but I don't feel I am consistent enough with this color to do it. I’ll need the ability to walk the car and do orientation coat on the whole thing to get it right.
Love this build but seeing pros who I know HAVE TO be way better than me Fight with this color, guided me to take the Path of least resistance.
If materials were free I might attempt it, but even then probably not.
Rich H.
Esse Quam Videri
[Re: EvilB1Dart]
#3135001
04/04/23 10:16 AM
04/04/23 10:16 AM
ZIPPY
S.E. Michigan
Thanks Wes!
I'm really Giving it my best shot but trying to keep the whole effort in balance from a time and "type of build/what are we really doing here" perspective.
Here are a few screen clips from a video after I pulled the tape.
Been studying and practicing soft edge masking on primer for a little while now, this is my first foray into doing it on a topcoat. Corners of the trunk jambs came out better than expected and should prep well for blending when I final sand the exterior.
I'll get more practice doing masking again in the other direction later, when I reverse mask those same areas to do the exterior.
Rich H.
Esse Quam Videri
[Re: hemi-itis]
#3135029
04/04/23 11:29 AM
04/04/23 11:29 AM
Posts: 10,022 MN
JERICOGTX
MN
When i worked in a body shop, there were 3 colors everyone hated to paint. White, gold, and silver. One speck color off, and it wouldn't match. Once saw a simple fender replacement that ended up almost a complete respray, because the blend was so messed up.
69 GTX
68 Road Runner
[Re: dvw]
#3136311
04/07/23 10:20 PM
04/07/23 10:20 PM
ZIPPY
S.E. Michigan
As I remember those door skins actually bow inward from front to back slightly. Like if you put a straightedge all the way from the front edge to the back edge. Doug They do. I finally noticed it. I don’t notice that on the vehicle but it’s there.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3137329
04/12/23 10:24 AM
04/12/23 10:24 AM
ZIPPY
S.E. Michigan
Hit the shop at 6am today to hose on some clear coat before work. I’m really loving the original color combo, and it sure makes me happy to do good quality work.
Had a few issues with the basecoat but like everything else they were 100% my fault, repaired them last night and moved on, can’t tell anymore and will probably Forget it happened.
Rich H.
Esse Quam Videri
