Page 1 of 3 1 2 3
dyno time #3127964
03/09/23 10:45 PM
03/09/23 10:45 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
just dropped off my 529 BB local s. jersey guy. should be ready next week I'm 2nd in line ! Good to see these local engine guys this busy.
Combination mega block, 13.13.1 , s r heads by Porter racing, 371/290 @ 700 . Milodon dual line system , 1150 thumper reworked dominator carb , indy single plane , crank trigger, lunati solid roller
710/711 lift 282/290 at .050. Hughes 1.5 roller rockers. bronze bushed lifter bores . vacuum pump, diamond pistons gas ported .043 top ring!
hoping to see 785 hp/ maybe 660 ft lbs. what you guys think?
Re: dyno time [Re: dart9ss] #3127970
03/09/23 10:53 PM
03/09/23 10:53 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Your goals sound reasonable.
69 GTX 68 Road Runner
Re: dyno time [Re: JERICOGTX] #3128033
03/10/23 09:13 AM
03/10/23 09:13 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I had an extremely similar combo. Made 786 hp on the Dyno. Forget the torque.
Re: dyno time [Re: markz528] #3128160
03/10/23 02:35 PM
03/10/23 02:35 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have an SR combo going together now (HardcoreB's old engine that he's re-vamping for me). In it's past form it made about 770 or so with a tunnel ram, but that was at only 11:1 So I think your goals are reasonable too.
I expect mine with some compression bump will be in the 800hp area, depending how good the new intake is.
Re: dyno time [Re: dart9ss] #3128172
03/10/23 03:22 PM
03/10/23 03:22 PM
NC
440Jim Offline
440Jim  Offline
NC
I think your estimate is good. It could make a little more too.
Do your SR heads have the 2.25" intake valves?
Do you know the final intake port volume after porting?
Is the block bored to 4.500" ? That can help breathing compared to a 4.375" bore, etc.
What size headers? Dyno shop headers or car headers?
Re: dyno time [Re: 440Jim] #3128245
03/10/23 07:50 PM
03/10/23 07:50 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
2.19 intake valve. 4.508 bore I don't have the intake volume Dwayne might know it's his work. using my headers 2 1/8 to 4" collector with turn out extensions. it's an A arm car headers custom to the chassis.
Re: dyno time [Re: dart9ss] #3128250
03/10/23 08:24 PM
03/10/23 08:24 PM
AndyF Offline
AndyF  Offline
That combo could easily make more than 800 hp with the big bore size and good heads. You would need to port the intake to make the bigger numbers and the cam will have to be right on the nose. The cam specs seem too big for that engine but if Dwayne picked the cam then it should work. He knows his stuff.
My 514 with EZ heads made well over 800 hp with a smaller cam, but I had 1.85 Jesel rocker arms so it isn't a direct comparison.
Re: dyno time [Re: AndyF] #3128258
03/10/23 08:52 PM
03/10/23 08:52 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
flow numbers are incorrect ! more in the 350s / 260s @ 700 so ! will have to see. the car went 9 .00 with 272 / 284 roller. hoping the cam change should put an 8.90 on the window!
Re: dyno time [Re: dart9ss] #3128260
03/10/23 09:00 PM
03/10/23 09:00 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What weight and mph at 9.0? That would at least give you a hp starting point.
Any other changes aside from cam?
Re: dyno time [Re: dizuster] #3128288
03/10/23 11:15 PM
03/10/23 11:15 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
2785 W D .best 9.017 146 mph with good N J air! lol
Re: dyno time [Re: dart9ss] #3128349
03/11/23 10:30 AM
03/11/23 10:30 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Awesome Bob ! looking forward to seeing the results !
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: dyno time [Re: 11secdart] #3128361
03/11/23 11:08 AM
03/11/23 11:08 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
John Impulse racing in wall is handling it. He's right next to Martino and wild rides. nice set up he has. see you soon Bill.
Re: dyno time [Re: dart9ss] #3129652
03/15/23 02:50 PM
03/15/23 02:50 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
well here's the results. Got the flo numbers from Dwayne
s r flow #s
Lift—— I/E
.100— 73/57
.200—147/114
.300—212/165
.400—263/207
.500—310/239
.600—336/253
.700—348/264
.800—359/271
made six pulls . couldn't use my headers , 2 1/8 to 4" used 2" to 3 1/2" ,
Re: dyno time [Re: dart9ss] #3129672
03/15/23 03:45 PM
03/15/23 03:45 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Impressive numbers for such low RPM.
Re: dyno time [Re: dart9ss] #3129703
03/15/23 05:11 PM
03/15/23 05:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
Me thinks there is something goofy in this motor whiney work
Was the cam degreed? If so do you know where the intake lobe center was installed at? IF so, were?
If not it should be, I've built and dyno a bunch of BB Mopar stroker motors with similar parts and they made peak power above 6000 RPMs, more HP, power and torque than yours shruggy
What about valve spring pressures?
I'll look at your first post again to see if that was listed or not.
EDITED, 2nd look, I see the comment about retarding the cam 4 degrees, why? shruggy
Every BB Mopar motor I've dyno and change the cam LSA timing liked from 2 to 6 degrees advanced on the intake lobes, none of them like straight up or retarded on the intake lobes, none of them.
That being said I have never used a cam as large as yours is on the duration shruggy
I'm still learning so thanks a bunch for posting your dyno sheets bow up
Re: dyno time [Re: Cab_Burge] #3129718
03/15/23 06:15 PM
03/15/23 06:15 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
cam was installed at 108 . I also was wondering why the max power was before 6000. I know the headers used where smaller. I have a light car and advancing the cam I understand would move the torque and hp down the rpm range. This was a refresh with a bigger cam. I'm happy with the outcome. moved the timing ,around, retarding -4 . we added 100 rpm to peak hp and picked up 11 hp.Going to see if the aerospace vac pump needs rebuild. I would like to see more inch's of vac. hey maybe its the Dyno !
Re: dyno time [Re: dart9ss] #3129785
03/16/23 12:11 AM
03/16/23 12:11 AM
AndyF Offline
AndyF  Offline
That dyno sheet looks like the cam is way smaller than 280/290. Are the heads MW port size? I'm assuming they are since you are using an Indy intake but something moved the power peaks down lower than expected. Did you physically verify that the camshaft was the one that you ordered? The dyno sheet looks like the cam is maybe 20 degrees smaller than what you posted.
And what is going on with the oil pressure? That isn't a good situation with the pressure climbing as the RPM goes up. The pressure relief valve might be stuck or blocked. You should set the relief spring so the max pressure is around 70 psi.
Re: dyno time [Re: AndyF] #3129786
03/16/23 12:16 AM
03/16/23 12:16 AM
AndyF Offline
AndyF  Offline
Here is a dyno sheet of a 572 inch Mopar big block with EZ heads and a 280/296 cam. This engine pulls past 7000 RPM and makes more than 860 hp. I think you have something funky going on with your engine. Maybe the valve springs were not correct for the cam? This engine uses the 325 big EZ heads which flow pretty well but I'd think a set of fully prepped SR heads would flow more air than EZ heads. The intakes should be roughly the same but the SR heads should have a better exhaust.
Re: dyno time [Re: AndyF] #3129812
03/16/23 08:14 AM
03/16/23 08:14 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Yes Andy the oil pressure will be checked out. The cam was installed as per the cam card 108. Lift and duration was spot on when i installed it . don't know why the power band is below 6000. yes max wedge ported heads. porter racing set up my heads for me. The headers were pretty small he used I assume that also effects the power band. may have been 1 7/8 or 1 3/4 . Mine are 2 1/8 to 4 inch.
Re: dyno time [Re: dart9ss] #3129814
03/16/23 08:30 AM
03/16/23 08:30 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice motor, glad to see you have it back together and it'll run better once it's sorted and in the car. I agree that something is off that the engine power is at such a low RPM and falls off quickly.
Page 1 of 3 1 2 3
