Re: dyno time
[Re: dart9ss]
#3127970
03/09/23 10:53 PM
03/09/23 10:53 PM
Posts: 10,022 MN
JERICOGTX
MN
Your goals sound reasonable.
69 GTX
68 Road Runner
Re: dyno time
[Re: JERICOGTX]
#3128033
03/10/23 09:13 AM
03/10/23 09:13 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I had an extremely similar combo. Made 786 hp on the Dyno. Forget the torque.
Re: dyno time
[Re: dart9ss]
#3128349
03/11/23 10:30 AM
03/11/23 10:30 AM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
Awesome Bob ! looking forward to seeing the results !
Re: dyno time
[Re: dart9ss]
#3129672
03/15/23 03:45 PM
03/15/23 03:45 PM
Posts: 10,022 MN
JERICOGTX
MN
Impressive numbers for such low RPM.
69 GTX
68 Road Runner
Re: dyno time
[Re: dart9ss]
#3129703
03/15/23 05:11 PM
03/15/23 05:11 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
Me thinks there is something goofy in this motor Was the cam degreed? If so do you know where the intake lobe center was installed at? IF so, were? If not it should be, I've built and dyno a bunch of BB Mopar stroker motors with similar parts and they made peak power above 6000 RPMs, more HP, power and torque than yours What about valve spring pressures? I'll look at your first post again to see if that was listed or not. EDITED, 2nd look, I see the comment about retarding the cam 4 degrees, why? Every BB Mopar motor I've dyno and change the cam LSA timing liked from 2 to 6 degrees advanced on the intake lobes, none of them like straight up or retarded on the intake lobes, none of them. That being said I have never used a cam as large as yours is on the duration I'm still learning so thanks a bunch for posting your dyno sheets
Re: dyno time
[Re: dart9ss]
#3129785
03/16/23 12:11 AM
03/16/23 12:11 AM
Posts: 31,027 Oregon
AndyF
That dyno sheet looks like the cam is way smaller than 280/290. Are the heads MW port size? I'm assuming they are since you are using an Indy intake but something moved the power peaks down lower than expected. Did you physically verify that the camshaft was the one that you ordered? The dyno sheet looks like the cam is maybe 20 degrees smaller than what you posted.
And what is going on with the oil pressure? That isn't a good situation with the pressure climbing as the RPM goes up. The pressure relief valve might be stuck or blocked. You should set the relief spring so the max pressure is around 70 psi.
Re: dyno time
[Re: AndyF]
#3129786
03/16/23 12:16 AM
03/16/23 12:16 AM
AndyF
Here is a dyno sheet of a 572 inch Mopar big block with EZ heads and a 280/296 cam. This engine pulls past 7000 RPM and makes more than 860 hp. I think you have something funky going on with your engine. Maybe the valve springs were not correct for the cam? This engine uses the 325 big EZ heads which flow pretty well but I'd think a set of fully prepped SR heads would flow more air than EZ heads. The intakes should be roughly the same but the SR heads should have a better exhaust.
Re: dyno time
[Re: AndyF]
#3129812
03/16/23 08:14 AM
03/16/23 08:14 AM
Posts: 361 nj pine beach
dart9ss
nj pine beach
Yes Andy the oil pressure will be checked out. The cam was installed as per the cam card 108. Lift and duration was spot on when i installed it . don't know why the power band is below 6000. yes max wedge ported heads. porter racing set up my heads for me. The headers were pretty small he used I assume that also effects the power band. may have been 1 7/8 or 1 3/4 . Mine are 2 1/8 to 4 inch.
