Re: Do all Mustangs come standard with Autocrash installed?
[Re: Sniper]
#3128445
03/11/23 02:37 PM
03/11/23 02:37 PM
Posts: 19,587 north of coder
moparx
Serious question: What is it about the Mustangs that make them suddenly turn like that under hard acceleration? It seems like ALL of the Mustang crash videos have a handling scenario like that. Since this was on a track, I am assuming he didnt hit an oil-down or water spot. If you watch closely you will see something come out the bottom and bounce back towards the starting line. What it is, I do not know. possibly clipping the 60ft timer ? it usually boils down to a [semi ?] high performance car and a low performance driver. i wonder if unhooking the front or rear sway bar would help keep these cars from the "left turn Clyde........" syndrome ?
[Re: moparx]
#3131327
03/22/23 07:32 AM
03/22/23 07:32 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Have an 06 GT stick shift. I've heard it called the mustang curse. Something to do with the wheelbase is the best guess I have heard. All I know is drive very carefully if you go through water or are in the rain. I've had the car take off 2X since I've owned it starting in 2015. Raced a lot and this was all on the street after going through a puddle. Hit second gear and off to the left I went. Best I could do was countersteer and get off the gas. Happened extremely fast.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: klunick]
#3131339
03/22/23 08:59 AM
03/22/23 08:59 AM
Posts: 3,390 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
They come by it naturally. Especially leaving car shows...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Sniper]
#3131578
03/22/23 10:04 PM
03/22/23 10:04 PM
klunick
Southern Maryland
One thing I have noticed is that modern traction control does things that actively work against your input.
Been many a time the rear has gotten loose in slippery weather, I steering into it, traction control kicks in and the vehicle starts to get out of line big time. The only solution there is to get out of it, or lobotomize the traction control. On Mustang GTs and above you can turn off traction control
67 Barracuda FB
69 Superbee
[Re: klunick]
#3131611
03/23/23 08:34 AM
03/23/23 08:34 AM
Posts: 6,306 nowhere
Sniper
nowhere
Been many a time the rear has gotten loose in slippery weather, I steering into it, traction control kicks in and the vehicle starts to get out of line big time. The only solution there is to get out of it, or lobotomize the traction control. On Mustang GTs and above you can turn off traction control Yes, cause you have all the time in the world to do that when it happens.
[Re: Sniper]
#3132222
03/25/23 03:52 PM
03/25/23 03:52 PM
klunick
Southern Maryland
Been many a time the rear has gotten loose in slippery weather, I steering into it, traction control kicks in and the vehicle starts to get out of line big time. The only solution there is to get out of it, or lobotomize the traction control. On Mustang GTs and above you can turn off traction control Yes, cause you have all the time in the world to do that when it happens. He was at the drag strip
67 Barracuda FB
69 Superbee
[Re: wjb123]
#3132285
03/25/23 07:02 PM
03/25/23 07:02 PM
Posts: 15,931 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
You would think the people at track have launched the car hard many times before going to track and know the feel of the car, rwd, etc. and know how to recover from oversteer. The suspension doesn't appear stock, but I might be wrong. It seemed to hook up well. Front end didn't lift much but rear didn't squat either.
Edit: It did look like it was at shift point.
Facts are stubborn things.
[Re: klunick]
#3132373
03/26/23 08:25 AM
03/26/23 08:25 AM
Sniper
nowhere
Been many a time the rear has gotten loose in slippery weather, I steering into it, traction control kicks in and the vehicle starts to get out of line big time. The only solution there is to get out of it, or lobotomize the traction control. On Mustang GTs and above you can turn off traction control Yes, cause you have all the time in the world to do that when it happens. He was at the drag strip Apparently you race in slippery weather? I wasn't talking about this particular crash., or mudstains in particular but rather modern cars with "traction control" in normal daily driving, which a lot of mudstain wipeouts appear to happen as well.
