46RE with a non-lockup high stall converter?
#3127873
03/09/23 05:09 PM
03/09/23 05:09 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Quite simply, can I use a non-lockup converter in a later moder 46RE? I am going to let the Holley Terminator X run it, so I should be able to simply not activate lockup, but would I cause any other problems? I know, usually people want to go lockup for mileage. I want to use my 3200 stall converter.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 46RE with a non-lockup high stall converter?
[Re: 67Charger]
#3127883
03/09/23 06:01 PM
03/09/23 06:01 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
It won't work. The lockup spline count is different than the non lockup.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#3127884
03/09/23 06:15 PM
03/09/23 06:15 PM
67Charger
Erda, UT
I do love simple answers...
[Re: 67Charger]
#3128102
03/10/23 12:06 PM
03/10/23 12:06 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Quite simply, can I use a non-lockup converter in a later moder 46RE? I am going to let the Holley Terminator X run it, so I should be able to simply not activate lockup, but would I cause any other problems? I know, usually people want to go lockup for mileage. I want to use my 3200 stall converter. It's not a drop in if that is what the question is ... BUT ... if you stuff the front half of the 727 into your 46RE , input shaft and hub assembly , front drum? , pump with stator support, you will be able to use the convertor. Since is electronically controlled I see no reason why just leaving the circuit unenergized would cause an issue with it and all it's valves just being there since they will just dead end where the 727 parts have no passage to send the fluid during lockup. What are you going to do aboutthe govenor pressure circuit , will this be a manual shift valve body ?
[Re: 67Charger]
#3128813
03/12/23 04:46 PM
03/12/23 04:46 PM
Guitar Jones
Quite simply, can I use a non-lockup converter in a later moder 46RE? I am going to let the Holley Terminator X run it, so I should be able to simply not activate lockup, but would I cause any other problems? I know, usually people want to go lockup for mileage. I want to use my 3200 stall converter. What you need to swap can depend on the years of the two transmissions. You would be miles ahead if you used a 46RH instead. Swap the pump with reaction shaft, rear drum with input shaft and front drum from the 727 into the 46RH.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: moparx]
#3128845
03/12/23 08:05 PM
03/12/23 08:05 PM
Guitar Jones
would you use the full spring count in both drums ? if so, refresh my feeble noggin' as to what the extra [full count] springs will do. [faster release of the clutch pack, or extra clamping force with the hydraulic assist ?] it's hell to get old and forget stuff you have known for years ! I would say faster release but softer, slower apply with the full complement of springs. I don't worry about the rear drum as it has a Belleville spring and is applied in all forward speeds.
[Re: moparx]
#3128850
03/12/23 08:13 PM
03/12/23 08:13 PM
Guitar Jones
is that good or bad ? i see a couple of differing opinions over the years........ Depends on what you want, comfy street cruiser, more springs, turned up pressure with a transbrake, more springs, race full manual valvebody, probably less springs, but you can use that as part of the 2/3 shift timing tuning also.
[Re: Guitar Jones]
#3129004
03/13/23 11:46 AM
03/13/23 11:46 AM
JohnRR
U.S.S.A.
would you use the full spring count in both drums ? if so, refresh my feeble noggin' as to what the extra [full count] springs will do. [faster release of the clutch pack, or extra clamping force with the hydraulic assist ?] it's hell to get old and forget stuff you have known for years ! I would say faster release but softer, slower apply with the full complement of springs. I don't worry about the rear drum as it has a Belleville spring and is applied in all forward speeds. I would use whatever the current spring count is if the trans is working fine before changing parts.
[Re: moparx]
#3129678
03/15/23 03:57 PM
03/15/23 03:57 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
The 91.5-93 Diesel A518 is also non lockup, same with the early V10 truck.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
