A230 identify #3127612
03/08/23 07:03 PM
03/08/23 07:03 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
I've been looking for a large bearing 383 A230 trans & thought I found one on fb marketplace the seller was kind enough to remove the bearing cover & measure it for me,the cover is 5 + inches wide much larger than the 4 13/16 cover of the lg .bearing A230,the tail shaft housing has the duel shifter mounting & the ID pad only had PP230 1808 part# & no partial vin# leading me to believe it's a replacement trans, I suspect it's a truck trans,any ideas of what the application is ?,I tried to provide pictures but the files are too large as usual.
a2301.zip (0 downloads)
Re: A230 identify [Re: 71GTX471] #3127613
03/08/23 07:07 PM
03/08/23 07:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The truck 3-speeds did not get a VIN stamp & they have dual shifter bosses.
What are all the numbers on the pad?
Re: A230 identify [Re: Alaskan_TA] #3127625
03/08/23 07:40 PM
03/08/23 07:40 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Just what I posted that's it.
Re: A230 identify [Re: 71GTX471] #3127629
03/08/23 07:56 PM
03/08/23 07:56 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
I had an A230 from an E-body some years back, but I don't recall any real specifics about it.
I did learn there were 2 types for cars, basically a "regular" and an HD, which was for BBs.
Re: A230 identify [Re: topside] #3127687
03/08/23 10:46 PM
03/08/23 10:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My wild guess would be the 3 speed came from a mid 80s Dodge pickup, or possibly the same era Aspen/Valarie. During that time, most of the manual transmissions were the 4 speed OD, and those would have had the big front bearing cover to register in the OD bell. The OD bell had the larger transmission register, possibly for easier ID on the 4 speed OD compared to the 4 speed non-OD. The 3 speed just got caught up in the times.
So the question is, is just the bearing cover different, or does the trans have the bigger front bearing?
Re: A230 identify [Re: poorboy] #3127934
03/09/23 08:04 PM
03/09/23 08:04 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
I managed to add a picture of the backside of the bearing retainer in the opening post,you can see the witness marks of the actual bearing size vs the overall width of the bearing retainer,the bearing is the small size.
Re: A230 identify [Re: 71GTX471] #3128138
03/10/23 12:25 PM
03/10/23 12:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of an A-230 I pulled from an '75 B-van. It has the 5 1/8" bearing retainer and the 3.08 low gear.
Re: A230 identify [Re: 71GTX471] #3128404
03/11/23 11:47 AM
03/11/23 11:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a 230 in the garage It has the small bearing suport.Mine IIRc when the numbers were ran was from like a 70 or so B E body
Chrysler Firepower
Re: A230 identify [Re: poorboy] #3128475
03/11/23 03:01 PM
03/11/23 03:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The bearings & covers do not interchange.
/6, 318 & 340 cars used the small bearing / cover.
Not sure about /6 trucks, but for 318s in trucks 1970 & at least 1971, the A-230 had the large bearing / cover since the bell housing had a dual bolt pattern for the 435 4-speed.
383 & 400 car engines had the large bearing / cover.
Re: A230 identify [Re: John_Kunkel] #3129147
03/13/23 06:34 PM
03/13/23 06:34 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Thats the one John K.
