Re: 727 Forward Manual Valve Body - any better than the others?
[Re: carter]
#3127055
03/06/23 07:41 PM
03/06/23 07:41 PM
Posts: 361 mississippi
lostdog
mississippi
[Re: usp4u]
#3127056
03/06/23 07:42 PM
03/06/23 07:42 PM
lostdog
mississippi
[Re: lostdog]
#3127061
03/06/23 07:57 PM
03/06/23 07:57 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: DusterKid]
#3127180
03/07/23 09:06 AM
03/07/23 09:06 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I've run T/A 's with both FWD and RVB's they've worked flawlessly you just gotta remember to start your burnouts in second gear. I also have a Griner FVB that has worked flawlessly for years in my 904 with 5300 stall.
The advantage of RVB's for me is you pull back toward you down the track (more natural movement) and you can't accidently slam it into neutral on a hard 2-3 shift like you can with a FVB.
The downside is you gotta go back through first to get back to neutral...which sucks especially if you wanna unload the motor and coast past the traps
[Re: moparx]
#3127871
03/09/23 04:50 PM
03/09/23 04:50 PM
Cab_Burge
[Re: mrrandyj]
#3128551
03/11/23 07:26 PM
03/11/23 07:26 PM
Posts: 19,408 north of coder
moparx
so now, i'm more inclined to use a forward pattern, manual valve body for my charger, as [when i get it going that is] it will be a street/strip [airport drags] car. i have on the shelf, a B&M forward pattern, manual shift kit, that is low band apply. i also have a detent plate from [???] that fits my factory shifter i intend to use. i have read somewhere that the detent plates out there need to be "tuned up" somewhat, due to the fact the factory shifters move in an arc, while the detent plates move in a straight line. i have been looking at that the last few days, [as i have time] and can see the difference. with my machinist skills, that can be easily be taken care of. i also acquired a rusty chrome shifter i am going to modify by shortening the shaft by 2" [already done] and doing all the modifications to this shifter instead of my original, which is in perfect condition. my one buddy is going to make me a genuine walnut knob to match my wood grain grant steering wheel when he gets back from vacation in april. any thing i need to be aware of using the B&M kit ?
