hemi carb rebuild kits?
#3126898
03/06/23 08:29 AM
03/06/23 08:29 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
whats the best source for 66 carter rebuild kits? everyone is allover the place. are 66 different than 67?
Hell Hath No Fury Like Mine
Re: hemi carb rebuild kits?
[Re: cudaman1969]
#3126912
03/06/23 09:53 AM
03/06/23 09:53 AM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Probably check with Harm's.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#3127128
03/06/23 11:15 PM
03/06/23 11:15 PM
Posts: 1,321 VA
dragon slayer
VA
The Kit covers 66 thru 71 hemi and a few other AFBs. The issue will be the quality of the Accelerator pump in the kit. Hemi used the Carter 64-212 like most Chrysler AFBs of that era, and the aftermarket went generic. The other difference is the needle and seats. Most are .110. Hemi like Chrysler AFBs used .1015 #38 seats. So the fuel level can wind up being higher, for the same fuel pump pressure/float setting. Larger needle area means the fuel pressure exerts more force against float fulcrum which means fuel level will go higher to exert enough buoyancy force to keep needle closed.
SMP might be a little better than the walker kits I have seen. Can't speak to some of the custom kits on ebay. Can't be too many manufacturers making their own parts anymore.
Pay attention to the gaskets that come out of your carbs versus what you put in the carb. The kits give you all the options which is why the kit covers all years. 66-67 use the older style secondary venturi gasket. The newer ones are included for the 68 up.
