Re: I kind of like this Indy cross ram
[Re: AndyF]
#31238
09/30/06 11:46 PM
09/30/06 11:46 PM
Posts: 44,299 Bend,OR USA
Cab_Burge
Andy, I know you said that the carb. you got is one of the new Ultra Dominators but you might wnat to look at(if it has them)the power valve fuel holes in the metering block. I bought a 8896-1 several years ago and it had humongous PVRC in the metering plates, to big to be able to jet the carb down enough to get a good AFR reading at WOT with out making the motor detaonate at part throttle. The Carb. Shop was next door to the dyno shop and they fix the metering plates so we could still run the front power valve and block the rear one off, that made the jetting a lot easier to tune.
[Re: AndyF]
#31239
10/01/06 01:10 AM
10/01/06 01:10 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The LM1 is one of the greatest tuning tools ever. One of my next projects is to use the LM1 on my car and see if I can actually dial in a Holley Dominator so that it works on the street. I'm not sure if I can get it to a point where it drives super nice but I figured it would be a fun thing to mess with.
Andy, and this is what impressed me most about 1FastMopar's car during Drag Week! i asked the questions but Eddie wouldn't answer. i saw some things that were very interesting
we all know that a dominator will make the numbers, the multi carb setups are for those that want to be different
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: AndyF]
#31240
10/01/06 07:07 AM
10/01/06 07:07 AM
Andy, going from the oe maxwedge to the indy intake, what metering jets and metering rods did you use on your oe max wedge intake and what metering jets and metering rods on the indy 440-25 intake. my oe crossram uses 113 primarys 110 secondaries need some recommendations on jetting the indy intake
[Re: Michael]
#31243
10/01/06 05:58 PM
10/01/06 05:58 PM
Posts: 6,363 Aurora, Oh.
max_maniac
Aurora, Oh.
I remember 3 or 4 years ago when Indy came out with that manifold, a friend of mine installed that intake on his Max Wedge and picked up over a half a second over the OEM cross-ram. That manifold will make power!
That seems like it would not be possible but next year I may just find out for sure. Currently I'm running on OE max wedge intake and was thinking of going to the Mopar x ram or the Indy. I think this test Andy just did made up my mind. As of right now with an original x ram I have a best of 10.07 but in the heat it stays in the 10.10 to 10.15 range. I think the Indy intake would put me in the ball park for some high 9.90's in the heat which would be right on for the 10.0 class. Thanks Andy for doing the testing and posting the results. I currently have the 750 carbs and will start with them next year but may go to the 800's if needed.
[Re: max_maniac]
#31244
10/01/06 07:07 PM
10/01/06 07:07 PM
I GOT .4-.5 OUT OF THE BOX ON MY INDY 440-25 INTAKE COMPARED TO MY ORIGINAL MAX WEDGE CROSSRAM. I WENT FROM 10.70 TO 10.30 RIGHT OUT OF THE BOX AND THEN JETTED AND GOT ANOTHER TENTH OUT OF IT. YOU NEED SOME BIG METERING JETS FOR THIS INDY INTAKE. I THINK IT IS ONE UGLY PIECE BUT IT WORKS FOR SURE. SO YOU NEED TO KNOW: "WOULD YOU RATHER LOOK GOOD OR RUN GOOD" THAT IS THE QUESTION?
#31245
10/01/06 07:12 PM
10/01/06 07:12 PM
Posts: 5,620 long island NY
Ari440
long island NY
how tall is the indy crossram?
how much do they go for?
1.39 9.85 - 137 mph
[Re: Ari440]
#31246
10/01/06 07:19 PM
10/01/06 07:19 PM
i know they go for $1250.00 retail but call FAST68PLYMOUTH, i think He has a real good price on them
[Re: AndyF]
#31252
10/04/06 03:13 PM
10/04/06 03:13 PM
sixpackgut
Charleston
3 4412 500 CFM CARBS with the air horns cut down and the power valves blocked in the outboards is the route i would take. it would save several hundred dollars over six pack carbs
[Re: sixpackgut]
#31253
10/04/06 08:35 PM
10/04/06 08:35 PM
ANDY, WHATS THE PRICE FOR THE THROTTLE BRACKET AND LINKAGE RODS, I HAVE THE OFFSET TOP. I LIKE WHAT I SEE.
#31254
10/04/06 09:05 PM
10/04/06 09:05 PM
Ari440
long island NY
how tall is the indy crossram ?
to mount two HOLLEY 750,s what linkiage whould you use ?
can you mount the 750s holley inline ?
1.39 9.85 - 137 mph
[Re: john55]
#31257
10/05/06 06:45 PM
10/05/06 06:45 PM
ANDY,indy has a small offset top which is offset around 2" staggered, i've seen a intake with a jogged linkage rod, i made up a straight rod(not professionally done) waiting for your parts,with oe carb swivel ends, i think a small jogged linkage rod would work fine, pm me with a price on the throttle bracket, and linkage rod, i'll buy it immediately thanks, also i need one of those indy 2 piece valley covers machined so you can slip it under the heads so you dont have to remove the heads.
