Re: 833 won't shift out of 2nd under high RPM
[Re: 6T9Hemi]
#3138556
04/16/23 07:31 PM
04/16/23 07:31 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Are the shift struts soft enough to get ground up and not hurt the gears? If the strut springs are chewed or deformed then it may be laying in there somewhere. They are softer than the gears but all the remains of the strut key would be attached to the magnet in the form of metal "fuzz" I may have never been there from the start Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 6T9Hemi]
#3139032
04/18/23 03:28 PM
04/18/23 03:28 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Are the shift struts soft enough to get ground up and not hurt the gears? I don't think there is anything in there soft enough to get chewed up and you not knowing it happened. Did you take out the speedo adapter and fish around in the bottom of the tailhousing with a magnet?
[Re: JohnRR]
#3139136
04/18/23 10:28 PM
04/18/23 10:28 PM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
Are the shift struts soft enough to get ground up and not hurt the gears? I don't think there is anything in there soft enough to get chewed up and you not knowing it happened. Did you take out the speedo adapter and fish around in the bottom of the tailhousing with a magnet? A good suggestion and possibility however he stated, The retainer springs for the struts were wobbly looking and bent. . With the trans already out, I'd pull it apart
[Re: B1MAXX]
#3139287
04/19/23 01:26 PM
04/19/23 01:26 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
The shift struts are the 70+ wide style. I guess it could have broke in half and got spit out. It was one that was indexed by the spring. There was a lot of metal "fuzz" around the magnet. The gears all look fine. The wide style look softer that the earlier narrow struts.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: B1MAXX]
#3139385
04/19/23 09:22 PM
04/19/23 09:22 PM
TJP
Omaha Ne
They can pop out if the slider goes too far. usually during assembly they can also do so if the shifter is misadjusted or does not have stops when one UHH shifts abnormally LOL. I learned about this when I was 18 Yo and had no 🤑🤑
[Re: 6T9Hemi]
#3139446
04/20/23 09:26 AM
04/20/23 09:26 AM
JohnRR
The shift struts are the 70+ wide style. I guess it could have broke in half and got spit out. It was one that was indexed by the spring. There was a lot of metal "fuzz" around the magnet. The gears all look fine. The wide style look softer that the earlier narrow struts. They aren't softer than the narrow struts, are there any chipped teeth anywher? If it popped out while running and got into the teeth you would know it, it might have locked the trans till something else broke free/off.
