5.7 Swap Question #3124569
02/25/23 04:42 PM
02/25/23 04:42 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Hi, just picked up a 2004 RAM 2500 with a bad engine, fellow says it is locked up. I have a wrecked 2005 RAM 1500 with a good engine. Interchange manuals show them as not being swapable. Wondering if anyone knows what the differences are, and if they can be worked around. Any help would be much appreciated. Thanks. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 5.7 Swap Question [Re: BANDIT] #3124574
02/25/23 05:46 PM
02/25/23 05:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It will work. 05 1500 might have MDS (your 2500 does not) or plastic valve covers, leave MDS solenoids in and disconnected and swap your valve covers so you can bolt on your ignition coils.
Re: 5.7 Swap Question [Re: HotRodDave] #3124608
02/25/23 08:18 PM
02/25/23 08:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
IIRC trucks didn't get MDS until 2006. The LX platform cars got it in 2005.
Kevin
Re: 5.7 Swap Question [Re: Twostick] #3124649
02/25/23 11:34 PM
02/25/23 11:34 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
I wondered if it was MDS or possibly EGR related, ill have to look them both over real close when i drag the 2500 home. Thanks
4600 DA
Re: 5.7 Swap Question [Re: BANDIT] #3125164
02/28/23 12:00 AM
02/28/23 12:00 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
I just saw your post -
Not sure if you have an interest -
I have Dodge Service Manuals with Diagnostic Manuals on Disk 2004 -
Also 2004 - 2006 Dodge Ram Electric's
I used them for my 2004 Ram 5.7
if interested -
pm or email may be best -
They only see Stars...
when hit by a Mopar!
Re: 5.7 Swap Question [Re: BANDIT] #3125289
02/28/23 01:45 PM
02/28/23 01:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If it needs EGR added it takes 5 minutes to drill the passages even with the head on but make sure that #2 exhaust valve is fully closed while drilling so nothing gets in cylinder. Usually the NON EGR heads already have the bolt holes drilled and tapped but it still only takes a few minutes to do that also if it is a problem. I have not paid a whole lot of attention to what years and aplications did or did not have EGR I just add it if I need it and block it if I don't.
Re: 5.7 Swap Question [Re: HotRodDave] #3126310
03/03/23 11:47 PM
03/03/23 11:47 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
The 05 has an EGR valve, the 04 doesn't. I haven't checked on the MDS yet. Thanks for offer on discs, the dealer here in town has been real good on letting me look at his stuff, so I'll pass for now. Jim
4600 DA
