tightening lower control arm pivot shaft #3124628
02/25/23 09:57 PM
02/25/23 09:57 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Hey everybody,s
I replaced my lower control arm bushings and have a question about tightening the control arm pivot nut. I read where the car needs to be on the ground with weight on the suspension.
Does the engine need to be in place too? It is out of the car right now.
Britt
Re: tightening lower control arm pivot shaft [Re: pwr440] #3124633
02/25/23 10:07 PM
02/25/23 10:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No the engine does not need to be in. Set the torsion bars for the desired ride height and torque the nuts.
Re: tightening lower control arm pivot shaft [Re: NITROUSN] #3124637
02/25/23 10:22 PM
02/25/23 10:22 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks man...appreciate the help.
Britt
Re: tightening lower control arm pivot shaft [Re: pwr440] #3124640
02/25/23 10:31 PM
02/25/23 10:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Britt
No problem. Good luck.
Re: tightening lower control arm pivot shaft [Re: NITROUSN] #3124732
02/26/23 10:50 AM
02/26/23 10:50 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Not sure about the amount of weight needed for that. On the later Transverse T bars the service manual says to set the lower arm to a certain measured distance and then tighten.
Re: tightening lower control arm pivot shaft [Re: pwr440] #3124746
02/26/23 11:39 AM
02/26/23 11:39 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've always had everything installed and the height adjusted to desired height, and then torque the pivot to spec. The belief is that the bushing is at a relaxed state and can more easily travel as ride jousts occur as the bushing flexes. The pin, nor the shell and sleeve do not move as the car bounces along. To approximate engine weight (and other assemblies) load up the engine bay with buckets full of heavy metal.Weigh as you add more items to approximate weight of items yet to install.
I will add that if everything is cinched down without the engine weight with the engine out of the car, then engine installed AND the torsion bars tightened up more to regain the previously set ride height, it would be approximately same bushing orientation.
Option is to install lca bushing and tighten enough to mostly set the bushing shaft and final torque after final engine install. To remind tightening finish up work, hang a tag on steering wheel and add to your list as a reminder. I've been using tags for years adding to the list and checking off to avoid aawschit moments.
Re: tightening lower control arm pivot shaft [Re: pwr440] #3124748
02/26/23 11:49 AM
02/26/23 11:49 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The nuts should be tightened in the most normal driving position. If that can be duplicated without the engine in place, then fine. But I always wait until the engine is in and the ride height is set to put the final torque on the nuts.
Master, again and still
Re: tightening lower control arm pivot shaft [Re: srt] #3124750
02/26/23 11:51 AM
02/26/23 11:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Height is not really important as long as there is space between the LCA bumper and frame. You will need to readjust the height when you get the engine in anyway.
Re: tightening lower control arm pivot shaft [Re: srt] #3124888
02/26/23 08:39 PM
02/26/23 08:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Myself, I do not tighten ANY of the suspension bushings until the front end is completely loaded. I have seen many fail due to stress from being in a constant twisted state. Urethane being an exception. However I still err on the side of caution twocents beer
Re: tightening lower control arm pivot shaft [Re: Jim_Lusk] #3124889
02/26/23 08:42 PM
02/26/23 08:42 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
good info and tips! Thanks!
britt
Re: tightening lower control arm pivot shaft [Re: pwr440] #3124939
02/27/23 12:32 AM
02/27/23 12:32 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
The arm rotates around the pivot when adjusting ride height. Torsion bar does not move. LCA bushing sees no change in stress, but you'll at least want the car even left and right. Exact ride height isn't important and can be changed later. The important thing is to have the as driven weight on the suspension when the pivot pin is torqued so it's relaxed when the car is parked, and equally stressed in jounce and rebound when driving.
