Mallory Distributor ID #3123798
02/22/23 07:43 PM
02/22/23 07:43 PM
michigan
440whiteboy Offline OP
michigan
Hello -
Digging through my storage finding more parts -
came across this Mallory Distributor from my 70 cuda box -
Can anyone ID this to confirm what it goes to?
small block? big block?
could not find this exact one on any charts online -
raised casting on main body is 577
Top cam plate # 25608
Bottom plate # 25979 B - RH
Mallory Tag # YL - 579 - HP
They only see Stars...
when hit by a Mopar!
Re: Mallory Distributor ID [Re: 440whiteboy] #3123840
02/22/23 10:05 PM
02/22/23 10:05 PM
no part #?
Re: Mallory Distributor ID [Re: Cab_Burge] #3123859
02/22/23 11:00 PM
02/22/23 11:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
try google whistling
Re: Mallory Distributor ID [Re: 440whiteboy] #3123996
02/23/23 02:38 PM
02/23/23 02:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Small block, dual point, centrifugal advance.
Re: Mallory Distributor ID [Re: 440whiteboy] #3124040
02/23/23 04:50 PM
02/23/23 04:50 PM
t kind of looks like a bare Unilite unit to me confused
Re: Mallory Distributor ID [Re: John_Kunkel] #3124190
02/24/23 10:51 AM
02/24/23 10:51 AM
michigan
michigan
It does have spring mechanism set up below you can see and I can turn with a screw driver -
google search is showing for sale ad's - 273 - 318 - 340
cannot find a chart ?
if this was a dual point - in the parts bag is only 1 point -
person I bought car from had this in a box apart ???
dont know why he would ?
should I look for a second point before I attempt to sell this?
part # 25042 on the point
Re: Mallory Distributor ID [Re: 440whiteboy] #3124219
02/24/23 01:19 PM
02/24/23 01:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
YL-579-HP Is a small block. Just google the number.
Re: Mallory Distributor ID [Re: 440whiteboy] #3124246
02/24/23 02:47 PM
02/24/23 02:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You can run a 8 lobe cam dual point distributor on 1 set of points. adjust the dwell to ~ 30°
if i am not mistaken you can also convert it to electronic with a unilite kit but don't quote me on that wink
Re: Mallory Distributor ID [Re: NITROUSN] #3124328
02/24/23 08:10 PM
02/24/23 08:10 PM
michigan
michigan
yes - what I did
Re: Mallory Distributor ID [Re: TJP] #3124329
02/24/23 08:12 PM
02/24/23 08:12 PM
michigan
michigan
I did see the conversion kits for sale -
thanks -
Re: Mallory Distributor ID [Re: TJP] #3124331
02/24/23 08:15 PM
02/24/23 08:15 PM
michigan
michigan
This is an 8 lobe - yes
Question -
got me thinking about the dual point thing - what is the advantage from single point?
quicker firing? less stress on the single point?
Re: Mallory Distributor ID [Re: 440whiteboy] #3124337
02/24/23 08:31 PM
02/24/23 08:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Question -
Longer dwell time
