Re: Piston Height [Re: Wicked49670dart] #3124942
02/27/23 12:39 AM
02/27/23 12:39 AM
Originally Posted by Wicked49670dart
Block is a 73, ARP main studs with Hughes girdle. ARP head studs also. Steel caps. Same setup as my 496. H beam rods with 7/16 ARP 2000 rod bolts upgrade from 440 source. I did upgrade to the lighten crankshaft also.
You should have bought a new race block instead of the girdle and steel caps work twocents shruggy
Good luck luck
Re: Piston Height [Re: polyspheric] #3124980
02/27/23 10:16 AM
02/27/23 10:16 AM
an8sec70cuda Offline
Originally Posted by polyspheric
I disagree.
It's going to be less timing (knock) sensitive with that tight of a quench
Quench Cut - Chamber Softening - Nitrous Friendly Chamber
Creating this shape on the surface of the head changes the way the flame front travels throughout the cylinder by slowing down how fast the flame travels. This allows for a wider tuning window in boosted & nitrous combinations when it comes to timing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston Height [Re: an8sec70cuda] #3125024
02/27/23 01:21 PM
02/27/23 01:21 PM
NY
challenger451ci Offline
NY
I disagree.
Softening the chamber is going to typically yield more quench volume and a less timing sensitive chamber, correct? If he has an IS plate, I would ask Steve what he thinks before you button the motor up.
Re: Piston Height [Re: challenger451ci] #3125031
02/27/23 01:59 PM
02/27/23 01:59 PM
I disagree.
Yes. The tight quench everyone wants for a NA combination will yield a timing sensitive/narrow tuning window in a nitrous or boosted application.
CHIP
