70 challenger exhaust tips position.
#3123500
02/21/23 07:54 PM
02/21/23 07:54 PM
Posts: 1,191 imperial mo.
stickman
imperial mo.
Maybe I am overthinking this. But how far do the tips stick out of the rear valance? I am installing my system and they are out about 1 and 1/2 inch at the top. It looks like too much to me but have nothing to compare it to. Thanks guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 70 challenger exhaust tips position.
[Re: stickman]
#3123547
02/21/23 11:22 PM
02/21/23 11:22 PM
Posts: 20,699 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Hard to find any online pictures that really show them up close, and then you don't know it's correct either. Backside of the ECS Challenger video. Not sure if this helps or not? https://youtu.be/731E0GoXa6k
[Re: EV2RTSE]
#3123966
02/23/23 01:10 PM
02/23/23 01:10 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
IMO about an inch looks right. Not flush with the valance and not sticking out too far either.
I agree. I see so many that I think stick out way too far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3124283
02/24/23 04:19 PM
02/24/23 04:19 PM
6PKRTSE
Motor City
Unfortunately, my exhaust doesn't go all the way back.
[Re: 6PKRTSE]
#3124312
02/24/23 06:58 PM
02/24/23 06:58 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Six Pack RT SE, Have you tested those new Caltracs. What front and rear spring segments did you order. My Springs line up with the Exhaust tips also, so no tips on my Challenger eitther.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#3124384
02/24/23 10:32 PM
02/24/23 10:32 PM
6PKRTSE
Motor City
Yes, they have been tested and they work phenomenal. I don't remember for sure but a 22" front segment sticks in my head.
[Re: 6PKRTSE]
#3124415
02/25/23 12:40 AM
02/25/23 12:40 AM
hemicar1971
Chicago Blackhawks
Working on an Old Hemi Prostock at present and just put the Caltracs in the Cuda. 21 inch front 35 inch back wanted to move the axle back to the middle of the wheel well to make the tire look centered. The wheel base when raced was 106.5 inches not 108 so now we gained back 1 inch to 107.5. Also went with the rear spring that goes between the Slider and the eye to lower the car just a little but if that is not suited when testing the Cuda will go with the normal way the rear spring going under the eye. Did you pick up much 60 foot, also running a rear sway bar and Wheelie bars off the axle location but will have the capabilty to run those old drop down old school wheelie bars. Lots more work to go on this car to make it look like the old 1972 Pro Stocck if was in 1972. Could of restored the Cuda it is a 1971 Hemi Cuda but thats not our way, would rather trailer it to the track then to a car show and a lot more fun running at 150 MPH than having it sit indoors looking pretty.
[Re: hemicar1971]
#3124581
02/25/23 06:10 PM
02/25/23 06:10 PM
6PKRTSE
Motor City
Yes. I am running a Anti-roll bar and wheelie bars.
[Re: 6PKRTSE]
#3124740
02/26/23 11:26 AM
02/26/23 11:26 AM
Posts: 19,521 north of coder
moparx
are the arb bushings used flanged brass or bronze bushings ? if so, what thickness and length are they, and how are they holding up wear wise ? why did you choose them instead of poly or a nylon type ?
[Re: moparx]
#3124760
02/26/23 12:10 PM
02/26/23 12:10 PM
6PKRTSE
Motor City
Oil lite bronze. Holding up fine. Grease zerk helps also.
[Re: stickman]
#3125061
02/27/23 04:24 PM
02/27/23 04:24 PM
Posts: 1,236 Chicago, IL
PLUM_72
Chicago, IL
On both sides of the trunk pan there is an indentation with two holes. This was used for the hanger bracket and clamp which attached the muffler to the exhaust tip. You might be able to eyeball this point in your car and get an idea of position. You can also reference the pictures at ECS and Accurate Exhaust.
1972 Dodge Challenger
