Eddy Pro Flow 4 EFI systems, how tuneable? #3122623
02/18/23 07:14 PM
02/18/23 07:14 PM
Cab_Burge Offline OP
I'm looking at options for my 360 LA turbo build, have any of you use one of those with a turbo or blower for a street and strip build?
I see in their product description on Summits site that you need a two bar MAP sensor if you are blowing using boost through one of them. They say it comes with 35 Lb. injectors also so I'm going to assume using a small turbo on that system will require using bigger injectors, yes? I have set of 65 Lb injectors on another intake that I have never used them on (I used a Holley Dominator carb that A.J. converted to E85 for me years ago on that manifold) I'm thinking I should send them in for inspecting and rebuilding, if needed , before trying to use them on the Pro Flow 4 system work
They say that throttle body will flow 1000 CFM so I'm hoping that will work good on this deal luck
All new venture for me, EFI with a turbo using E85, what can go wrong with this whistling luck
Thanks in advance for all of your help, I hope I'm not biting off more than I can chew whistlingluck
Re: Eddy Pro Flow 4 EFI systems, how tuneable? [Re: Cab_Burge] #3122633
02/18/23 08:08 PM
02/18/23 08:08 PM
AndyF Offline
AndyF  Offline
Not really tuneable. You download the closest tune from the Edelbrock website and hope it is close enough.
Re: Eddy Pro Flow 4 EFI systems, how tuneable? [Re: AndyF] #3122642
02/18/23 08:48 PM
02/18/23 08:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would use a Holley efi set up, also there is High & low impedance injectors, some systems can only use one type
Re: Eddy Pro Flow 4 EFI systems, how tuneable? [Re: Cab_Burge] #3122650
02/18/23 09:12 PM
02/18/23 09:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Go with a Holley HP or better yet a Dominator efi.
Getting into a system that is essentially locked to the end user will just be frustrating and not end well.
I don’t recommend any lower end systems for anyone that’s performance oriented. A mild build for a driver type car can use the less optimal systems, but my gut feeling is you won’t want to just putt around after feeling real power come so easy compared to anything you’ve done before.
Re: Eddy Pro Flow 4 EFI systems, how tuneable? [Re: TRENDZ] #3122680
02/18/23 10:17 PM
02/18/23 10:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You need to start learning the Holley software for your other build anyway.
I this build needs boost control, wide band and a 3 bar map
Re: Eddy Pro Flow 4 EFI systems, how tuneable? [Re: Cab_Burge] #3122705
02/19/23 12:36 AM
02/19/23 12:36 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
DON'T do it! The eddy system has NO data logging, you will be lost in the sauce. Personally, I use a Ms3pro system, but I wouldn't recommend it because the leaning curve is soo steep. If I were you, I would go with one of the Holley systems. There was a discussion about this same subject 3 years ago. link
Joe
Without Data, you’re just another guy with an opinion.
