I'm looking at options for my 360 LA turbo build, have any of you use one of those with a turbo or blower for a street and strip build?
I see in their product description on Summits site that you need a two bar MAP sensor if you are blowing using boost through one of them. They say it comes with 35 Lb. injectors also so I'm going to assume using a small turbo on that system will require using bigger injectors, yes? I have set of 65 Lb injectors on another intake that I have never used them on (I used a Holley Dominator carb that A.J. converted to E85 for me years ago on that manifold) I'm thinking I should send them in for inspecting and rebuilding, if needed , before trying to use them on the Pro Flow 4 system
They say that throttle body will flow 1000 CFM so I'm hoping that will work good on this deal
All new venture for me, EFI with a turbo using E85, what can go wrong with this
Thanks in advance for all of your help, I hope I'm not biting off more than I can chew
