‘69 GTX- Engine Compartment Rehab #3120269
02/09/23 03:11 PM
02/09/23 03:11 PM
Upper Midwest
Black_Sheep Offline OP
Upper Midwest
I’ve been meaning to freshen things up under the hood for a few years, I finally got around to it this winter. The engine still runs great but had some oil leaks and things were starting to look a little grungy.
Pic#1: Initial disassembly
Pic#2: Drivetrain removal
Pic#3: Engine compartment cleaned, detailed and ready for the engine re-installation.
Pic#4: Final stages of engine preparation, now resealed, repainted and better detailed than when I first built it in the late ‘90’s
3592F16B-F967-4A92-B0DF-674138F151DA.jpeg02E81AB0-D468-4174-AE2B-30BE03CC7B2A.jpegCC7A6571-9521-4F27-B5BA-E4EBED65D9EF.jpeg46C36F11-4F91-4648-B9EF-E5CA35C39770.jpeg
'69 Plymouth GTX
See you on the street...
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3121644
02/15/23 12:11 AM
02/15/23 12:11 AM
Upper Midwest
Upper Midwest
We got the engine back in the GTX on Saturday morning and spent the rest of the afternoon hooking things up.
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3121649
02/15/23 12:54 AM
02/15/23 12:54 AM
Upper Midwest
Upper Midwest
The next task is the front suspension. I just finished restoring the last of the front end hardware so all of the parts are ready to go. A little clean up in the wheel wells and I can start bolting parts back on...
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3122073
02/16/23 02:22 PM
02/16/23 02:22 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Excellent!
Slightly off topic...how does that floor hold up to this sort of work (cherry pickers, jacks, etc.?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: ‘69 GTX- Engine Compartment Rehab [Re: DynoDave] #3122181
02/16/23 09:30 PM
02/16/23 09:30 PM
Upper Midwest
Upper Midwest
Originally Posted by DynoDave
Excellent!
Not too bad. The biggest problem is something heavy with small wheels can be hard to move on the “coined” surface. For example, I put my ‘58 on wheel dollies to get it close to the wall and make room around the GTX, it is a lot harder to get moving than it was on a bare floor. The cherry picker and floor jack are no problem. On the plus side, it cleans up nice and looks a lot better than the underlying concrete floor did.
It was too cold to do epoxy before I moved in. Once I moved in, what do I do with all my stuff? It takes several days to prep and coat the floor. There’s no way I’d leave my cars and tools unsecured in the driveway. Race deck seemed like the next best solution, installing it only took an afternoon.
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3122185
02/16/23 09:42 PM
02/16/23 09:42 PM
Upper Midwest
Upper Midwest
Everything is loosely installed, after the torsion bars go in I will finish connecting the sway bar and install the shocks. The GTX could be a roller again this weekend. I also need to get the grill and headlight bezels back on, the car looks so naked without them…
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3123053
02/20/23 12:34 PM
02/20/23 12:34 PM
Upper Midwest
Upper Midwest
She’s a roller again…
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3135836
04/06/23 07:17 AM
04/06/23 07:17 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Good to see you back Mark. Hope you are doing well. Maybe we can meet up at Mopars in the Park this year?
Jeff
69 GTX 68 Road Runner
Re: ‘69 GTX- Engine Compartment Rehab [Re: JERICOGTX] #3135843
04/06/23 07:53 AM
04/06/23 07:53 AM
Upper Midwest
Upper Midwest
Jeff
Thanks Jeff, I’m still alive and kicking. The GTX made it to the winners circle again after a 9 year hiatus, so I’ll be around all weekend. I’m sure we’ll cross paths…
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3137299
04/12/23 07:24 AM
04/12/23 07:24 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Where did you get the fuel line setup? I need that on my car!!!
Greg
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: ‘69 GTX- Engine Compartment Rehab [Re: MoparJunkie] #3137497
04/12/23 07:58 PM
04/12/23 07:58 PM
Upper Midwest
Upper Midwest
Greg
Made it myself…
'69 Plymouth GTX
Re: ‘69 GTX- Engine Compartment Rehab [Re: Black_Sheep] #3137635
04/13/23 07:47 AM
04/13/23 07:47 AM
MoparJunkie Offline
MoparJunkie  Offline
I was afraid you'd say that...Lol
