Page 4 of 4 1 2 3 4
Re: Stealth Heads, Max Wedge vs Std Port [Re: fast68plymouth] #3122157
02/16/23 08:15 PM
02/16/23 08:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by fast68plymouth
Quote
The MW w/ 2.19s was about 11 cfm better @ 0.200”, 0.300” and 0.400”, 7.5 cfm @ 0.500”, 6.5 cfm @ 0.600, and 3.5 cfm @ 0.700”.
I take it the std port CNC port still had the 2.14 valve?
Yes
Re: Stealth Heads, Max Wedge vs Std Port [Re: Mike@440Source] #3122448
02/17/23 10:20 PM
02/17/23 10:20 PM
Carson City
Mike@440Source Offline OP
Carson City
I’m back…apologies if you sent me a message and I missed it. I woke
up Thursday morning last week and felt fine for about an hour, then suddenly
had back pain, about a 6/10. I went into work anyway and made it until noon and
drove straight to the ER with a kidney stone from Hell.
Anyway, I’m just now catching up.
Hope you all have a great weekend.
Mike
Re: Stealth Heads, Max Wedge vs Std Port [Re: fast68plymouth] #3122451
02/17/23 10:33 PM
02/17/23 10:33 PM
Carson City
Carson City
My .02 is.........
With small port heads, like a steath or Ede Head......... the main reason one would bring them out to MW size would be to facilitate the use of a MW sized manifold.
Not so much for the perceived big increase in flow from the head itself.
had a conversation about this at work one day as well. The company only offers the
Std port CNC head now because the flow rates weren’t that different from each other,
but then you had to buy more expensive .650” offset rockers for the Super Stealth. It’s also one more part number
to warehouse, and that’s a negative when those parts don’t sell as quickly as the std port stuff.
Mike
Re: Stealth Heads, Max Wedge vs Std Port [Re: Mike@440Source] #3122483
02/18/23 04:09 AM
02/18/23 04:09 AM
A727Tflite Offline
A727Tflite  Offline
Mike
frown
I hope you passed it. They are not fun.
Re: Stealth Heads, Max Wedge vs Std Port [Re: sixpakdodge] #3122618
02/18/23 06:43 PM
02/18/23 06:43 PM
Carson City
Carson City
Hello everyone. This is my first post here, so I thought I'd post something as an icebreaker since I spend my days on the phone helping others. I get a few questions now and then from those who are looking at the Stealth heads and wonder if they can be ported to Max Wedge. I grabbed an old MW ported casting and rough-CC'd an intake port, doing the same for the current CNC offering. CC's are rough since I didn't have my plexiglass here at work.
MW = 270ish, just in case someone wants to run a MW-sized non-raised runner head. I didn't think I'd be one of those guys, but here we are...mostly because what I'm building needs to look "correct".
Standard port Stealths are 255ish as advertised; you'll have to port them to MW if you wish to go this route vs buying TF270's or a set of Indy's.
Mike
what do they pickup in flow?
Depends on who is doing the MW port work and the flow bench being used, assuming it's being used correctly.
Mike
We're well aware of those variances...so I interpret your response as meaning "Not enough, but you can do it if you want".
Exactly.
Page 4 of 4 1 2 3 4
