Fuel cells abodys #3121536
02/14/23 06:45 PM
02/14/23 06:45 PM
CA.
RAY1969CARS Offline OP
CA.
Please show pictures of your trunks!
Mopar or no car
Re: Fuel cells abodys [Re: RAY1969CARS] #3121618
02/14/23 09:57 PM
02/14/23 09:57 PM
Locomotion Offline
Locomotion  Offline
Angle brackets spanning the spare tire well with 1" X 1" square tubing bolted through & sandwiching the 4 tabs on the 5 gal. fuel cell. Height provides plenty of gravity feed to the fuel pump mounted under the trunk off of the frame rail with a FRAM fuel filter in between.
Probably should have straps over the top secured to the square tubing.
Re: Fuel cells abodys [Re: Locomotion] #3121648
02/15/23 12:34 AM
02/15/23 12:34 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Fuel cells abodys [Re: BloFish] #3121735
02/15/23 01:47 PM
02/15/23 01:47 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
