Replacing turn signal cam ('68 Plymouth) #3121560
02/14/23 07:53 PM
02/14/23 07:53 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
The turn signal cam in my '68 Road Runner has lost an ear, and I'm trying to replace it. The replacement piece that I bought only includes the cam, not the entire assembly. My problem is that I can't seem to get the cam separated. I've removed the bolt that connects to the turn signal lever and I can't tell what's holding the cam to the rest of the assembly (and I don't want to pry on it too much a break something). Any idea what I need to do to get it apart? Thanks in advance for any help!
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Replacing turn signal cam ('68 Plymouth) [Re: 1968RR] #3121645
02/15/23 12:16 AM
02/15/23 12:16 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need to add alittle more force because the cam is snug on the post that you removed the lever from.
Re: Replacing turn signal cam ('68 Plymouth) [Re: stumpy] #3121675
02/15/23 09:29 AM
02/15/23 09:29 AM
1968RR Offline OP
1968RR  Offline OP
Thanks! I'll give it a try.
Re: Replacing turn signal cam ('68 Plymouth) [Re: 1968RR] #3121732
02/15/23 01:32 PM
02/15/23 01:32 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Have you considered replacing entire switch? I know it's a little more labor because you have to access the connector down low and finding a NOS one can be expensive but if the cancel cam is bad the rest is probably brittle too. I've gotten lucky and found them on Feebay.
Facts are stubborn things.
Re: Replacing turn signal cam ('68 Plymouth) [Re: larrymopar360] #3121807
02/15/23 05:58 PM
02/15/23 05:58 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have found that when I replaced the cam, it lasted a while, but then started having light issues . . . replaced complete switch assembly - no issues. . . . .
Re: Replacing turn signal cam ('68 Plymouth) [Re: a12rag] #3122235
02/17/23 06:44 AM
02/17/23 06:44 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My buddy just went through this on a 68 charger. When he replaced the just the cam with a cheap repop, the front turn signals would not work. I gave him an old switch to use the entire switch and everything works.
Re: Replacing turn signal cam ('68 Plymouth) [Re: 1968RR] #3122245
02/17/23 08:16 AM
02/17/23 08:16 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I replaced the turn signal cam in my 69 Barracuda a few years back. I forget where I bought it, but it was one of the cheaper ones. I've never done anything like that before, so I just swapped it out and figured it'd be fine. Once I finally got the car running, I had issues with the lights. After a good bit of troubleshooting, it turns out the 2 wire prongs on the cam were not making contact. After messing with it for a while and bending the prongs I ended up getting them to work.
