Felpro 1105 head gasket on 4.375" bore #3121485
02/14/23 04:00 PM
02/14/23 04:00 PM
Utah
dartmeister Offline OP
Utah
I'm trying to finish up a 511/400 stroker motor and have a head gasket question. After measuring the piston to head clearance and figuring in the piston rock, I'm not sure how comfortable I am with using the .043 thick head gaskets I have. I'm thinking of trying the Felpro 1105 where they have a .051 thickness. Can I use that gasket on a 4.375" bore where it has bore size of 4.59"? Thanks.
Re: Felpro 1105 head gasket on 4.375" bore [Re: dartmeister] #3121500
02/14/23 04:31 PM
02/14/23 04:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just dealing with this same deal right now. Unless your deck and heads are smooth enough for an MLS gasket it's your only choice. The engine I'm doing for a friend has already been decked at least once and heads have been surfaced twice so the pistons are already almost zero. I have the 1105's on the parts shelf now and I think I will be OK judging by the search on this site for that gasket twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Felpro 1105 head gasket on 4.375" bore [Re: fourgearsavoy] #3121504
02/14/23 04:39 PM
02/14/23 04:39 PM
Utah
Utah
Gus beer
Thanks for the info. Mine has been decked before and the pistons are .006" above deck height at TDC, and these short skirt pistons rock a little more than I'm used to with a standard stroke 440 piston. I may be okay with my .043" thick copper gaskets I have on hand but I don't feel like tapping a piston on the head.
Re: Felpro 1105 head gasket on 4.375" bore [Re: dartmeister] #3121599
02/14/23 09:17 PM
02/14/23 09:17 PM
Utah
Utah
Anyone else using Felpro 1105 head gaskets and if so what size bore are you using them on?
Re: Felpro 1105 head gasket on 4.375" bore [Re: fourgearsavoy] #3121766
02/15/23 03:34 PM
02/15/23 03:34 PM
Utah
Utah
Gus beer
Gus what is the bore size on the motor you are going to use the 1105’s on?
Re: Felpro 1105 head gasket on 4.375" bore [Re: dartmeister] #3121863
02/15/23 08:50 PM
02/15/23 08:50 PM
Rittman Ohio
Rittman Ohio
The bore is 4.360 just a stock 440 block with 0.40 over SRP pistons. I will take a pic tomorrow of the gasket on the block. I don't have the heads back yet so I can't show it on the head. This particular block has been machined at the top of the bore to unshroud the valves.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Felpro 1105 head gasket on 4.375" bore [Re: fourgearsavoy] #3121883
02/15/23 10:03 PM
02/15/23 10:03 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
What's wrong with using the 1009 gasket? I've been using them on my 4.400 bore 400/455 stroker for 7 years with no problem.
Re: Felpro 1105 head gasket on 4.375" bore [Re: rebel] #3121906
02/15/23 11:00 PM
02/15/23 11:00 PM
Utah
Utah
I’m looking for a little thicker head gasket than the 1009. Also the 1009 overhangs a little bit at certain spots on my blocks bore.
Re: Felpro 1105 head gasket on 4.375" bore [Re: dartmeister] #3123522
02/21/23 09:36 PM
02/21/23 09:36 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I'm using the Felpro 1105 on my 440 + .040 (4.360") w/ Indy EZ heads and have no issues. Been together for 3 years now.
Re: Felpro 1105 head gasket on 4.375" bore [Re: 1969RR] #3124827
02/26/23 04:12 PM
02/26/23 04:12 PM
Utah
Utah
Thanks that's good to hear.
Re: Felpro 1105 head gasket on 4.375" bore [Re: dartmeister] #3124840
02/26/23 05:47 PM
02/26/23 05:47 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
That's the same gasket I'll be using on my 512, Felpro states that is the best gasket in that bore size. Felpro 1009 hung into the bore on my motor, my bore size is4.3756.Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
