Will Edelbrock Question 1906 in 1972
#3121259
02/13/23 07:28 PM
02/13/23 07:28 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hi! I would like to know if an AVS 2 1906 would fit my cast iron intake? I have a stock 1970 440 engine that has a stock 1971 intake. Also, will it work with a stock air cleaner and fresh air hood? Is it easy to hook up the electric choke? Can someone tell me the right part number for the carb for my car? It's a 4 speed with 354 gears. Finally,do you need an adapter for the intake for the carburetor? What gaskets need to be used?
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Will Edelbrock Question 1906 in 1972
[Re: GTXKARL]
#3121272
02/13/23 08:42 PM
02/13/23 08:42 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have bolted 650 Eddy carbs to factory iron intakes before and they work fine. Your electric choke is easy to hook up and there are many diagrams and videos in the net for you to choose your best option. The AVS 2 will work better than the factory carb because the annular boosters give better low end throttle response Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: TJP]
#3121347
02/14/23 01:02 AM
02/14/23 01:02 AM
Posts: 10,209 Someplace you aren't
SomeCarGuy
The bore size needs to be explored as stated above. You might look into if these are similar enough to maybe use the factory choke stat and get away without the electric to save a few bucks.
I want my fair share
[Re: SomeCarGuy]
#3121349
02/14/23 01:26 AM
02/14/23 01:26 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am running an AVS-2 on a stock 340 spreadbore Thermoquad intake and have zero fitment issues.
And I love this AVS-2, it's even better than the eddy perfomer carbs, and still has a very similar all in 4bbls open moan.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
