hemi mls gasket leaks ? #3120375
02/10/23 12:09 AM
02/10/23 12:09 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
who here has used mls head gaskets on their alu head iron block hemi and had oil seeping out between head and block ?
i think mine are leaking oil ?
is there a sealer to put on the gaskets to stop this ?
thank you !
Re: hemi mls gasket leaks ? [Re: calrobb2000] #3120397
02/10/23 07:52 AM
02/10/23 07:52 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I use MLS Cometics on my hemi. I don't have any leaking with the gaskets. I coated both sides of the gasket with copper coat spray sealant before installation. I thought I had a leak between the gasket and the head or block once, but that turned out to be a leak where the intake seals against the block and head. I re-sealed the intake and it's been dry since. This is a common issue with Hemis. I also have aluminum heads on an iron block.
Re: hemi mls gasket leaks ? [Re: blowndart] #3120426
02/10/23 11:39 AM
02/10/23 11:39 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
No leaks with my MLS gaskets on my Hemi. Also sprayed with copper coat.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: hemi mls gasket leaks ? [Re: 6PKRTSE] #3120438
02/10/23 12:43 PM
02/10/23 12:43 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
One other thing. If you haven't retorqued the heads bolt/studs after it was built, you should do that after it's seen a few heat cycles and it may help seal a small leak if the torque is off.
Re: hemi mls gasket leaks ? [Re: blowndart] #3120481
02/10/23 03:27 PM
02/10/23 03:27 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
MLS head gaskets require extremely smooth surface finishes ... there should be specs with the new gaskets.... and your local machine shop should spend the time to get to those specs (heads and block deck).... otherwise, fluid leakage can possibly occur.
Re: hemi mls gasket leaks ? [Re: Mopar Mitch] #3120489
02/10/23 03:44 PM
02/10/23 03:44 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
From Tim Banning at FHO, smear a little of the Right Stuff gasket maker around the oil drain back holes. front and back, both sides of gasket.
Re: hemi mls gasket leaks ? [Re: calrobb2000] #3120490
02/10/23 03:55 PM
02/10/23 03:55 PM
On the Cometic MLS head gaskets for Hemiriod motors I have had to cut the rivets off so the heads would not try and pinch them between the heads and block. I learn also that the Cometic MLS head gaskets need a lot smoother head and deck surface than other composition head gaskets need to seal properly. Call them to get the correct RA number for the deck and head surfaces scope I can't remember if it is 35 or 50 RA confused
Re: hemi mls gasket leaks ? [Re: Cab_Burge] #3120552
02/10/23 08:35 PM
02/10/23 08:35 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
It's 50
2011 Drag Pak Challenger
Re: hemi mls gasket leaks ? [Re: blowndart] #3120572
02/10/23 09:55 PM
02/10/23 09:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: hemi mls gasket leaks ? [Re: fuseable] #3121087
02/13/23 09:30 AM
02/13/23 09:30 AM
an8sec70cuda Offline
iagree I've heard this from a few known hemi engine builders. Silicone works also. Works for me. up
CHIP
'06 GMC 2500HD LBZ Duramax
