Re: hemi mls gasket leaks ?
[Re: blowndart]
#3120426
02/10/23 11:39 AM
02/10/23 11:39 AM
Posts: 4,565 Motor City
6PKRTSE
Motor City
No leaks with my MLS gaskets on my Hemi. Also sprayed with copper coat.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: blowndart]
#3120481
02/10/23 03:27 PM
02/10/23 03:27 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
MLS head gaskets require extremely smooth surface finishes ... there should be specs with the new gaskets.... and your local machine shop should spend the time to get to those specs (heads and block deck).... otherwise, fluid leakage can possibly occur.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#3120489
02/10/23 03:44 PM
02/10/23 03:44 PM
Posts: 766 Midwest
fuseable
Midwest
From Tim Banning at FHO, smear a little of the Right Stuff gasket maker around the oil drain back holes. front and back, both sides of gasket.
[Re: fuseable]
#3121087
02/13/23 09:30 AM
02/13/23 09:30 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
From Tim Banning at FHO, smear a little of the Right Stuff gasket maker around the oil drain back holes. front and back, both sides of gasket. I've heard this from a few known hemi engine builders. Silicone works also. Works for me.
