Page 7 of 7 1 2 3 4 5 6 7
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #3114555
01/19/23 04:48 PM
01/19/23 04:48 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Here's my latest purchase, time to start putting those rear quarter windows back, picked these up from National Moparts here in Canada, this is the place I actually bought my car back in '92. Hey Nigel.  :cheers:
Removed the old seal, the new seal slides in and this little metal tab goes through the whole in the rubber seal. Used some silicone spray as the seal was a very tight fit; which of course you want.
As we know with most repro parts they are usually a little off, the hole that was drilled in the seal was out of place so I had to drill a new whole and it had to be a little more oval for the rubber seal to fit over it.
Finished product, I am very happy with it and glad it was available in the aftermarket, mine have always looked like crap.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #3114559
01/19/23 04:55 PM
01/19/23 04:55 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #3117538
01/29/23 04:47 PM
01/29/23 04:47 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good looking stuff.
So you applied a little of the RPM to protect the parts of the mechanism?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1972 Charger SE Project by CDN72SE [Re: DynoDave] #3120332
02/09/23 07:23 PM
02/09/23 07:23 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Exactly Dave. up
