Re: Probs with Milodon dipstick in 8qt pan
[Re: Sniper]
#3121425
02/14/23 12:57 PM
02/14/23 12:57 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Stopped by Summit to look at a Milodon HV water pump and there was a GMB Chinese water pump in the box ![down down](/ubbthreads/images/graemlins/custom/down.gif) Gus Had you gone to Milodon's website you'd know why and that it isn't just a repackaged pump. Well I went to Milodons's website and took a quick look and didn't find any information on why they use a CRAP water pump like a GMB unit. I've probably replaced a couple dozen leaking GMB pumps since they came onto the scene. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Sniper]
#3121456
02/14/23 02:50 PM
02/14/23 02:50 PM
Posts: 15,987 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It has nothing to do with windage trays.
Season 3, episode 32 Okay thank you I will check it out. It's disappointing to hear of QC issues with another company I use to be able to just buy their stuff and forget it. I always bought their water pumps (had early failures on Mopar HD ones of late) and thermostats. Another company like that, non-automotive though, is Sony. I use to be able to buy anything Sony and knew it was the best. Not anymore. I appreciate the info on tig welding extension and I do have someone that can do that. Once I pull the pan I'm going to know a lot more. I hope to get to it next week and have some answers...finally. Thanks all. Larry
Facts are stubborn things.
[Re: larrymopar360]
#3121490
02/14/23 04:05 PM
02/14/23 04:05 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I was the one posting the picture of their pickup sticking out past the oil pan rail. The windage tray fit very poorly as well and I used their dipstick and wasn't impressed with it either. Definitely tons of quality control issues with their parts. Of course after calling milodon though, they said they've never heard of any issues and that it was something wrong with my engine...... typical corporate response.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 73cuda340]
#3121511
02/14/23 04:55 PM
02/14/23 04:55 PM
Posts: 19,724 north of coder
moparx
years ago, i thought GMB pumps were the good ones ??? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) "how times have changed......." as to the dip stick [i have been called that before. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) ] sometimes drilling a small, 1/16" hole at the add and full marks on the stick helps the oil to stand out more. be sure to de-burr the stick on both side after drilling the hole, so as to not make the stick "stick" sliding up and down the tube, as well as insuring no metal chips get introduced into the pan. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: 73cuda340]
#3121518
02/14/23 05:31 PM
02/14/23 05:31 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I was the one posting the picture of their pickup sticking out past the oil pan rail. The windage tray fit very poorly as well and I used their dipstick and wasn't impressed with it either. Definitely tons of quality control issues with their parts. Of course after calling milodon though, they said they've never heard of any issues and that it was something wrong with my engine...... typical corporate response. I've got to check my engine build receipt but I believe Milodon was probably still making quality stuff when it was built. I believe it was around 2014. I barely drive the car 800 miles or so a year. My feeling now is the dipstick is not long enough. It seems to be the proper material and not some funky plating and doesn't feel like it's obstructed. I'm determined now to just pull the oil pan. I've already purchased the gasket set and doesn't appear it's entrapped by anything...fingers crossed I won't have to raise engine.
[Re: fourgearsavoy]
#3121652
02/15/23 01:39 AM
02/15/23 01:39 AM
Posts: 10,247 Someplace you aren't
SomeCarGuy
Stopped by Summit to look at a Milodon HV water pump and there was a GMB Chinese water pump in the box ![down down](/ubbthreads/images/graemlins/custom/down.gif) Gus Had you gone to Milodon's website you'd know why and that it isn't just a repackaged pump. Well I went to Milodons's website and took a quick look and didn't find any information on why they use a CRAP water pump like a GMB unit. I've probably replaced a couple dozen leaking GMB pumps since they came onto the scene. Gus I went and looked, but didn’t want to be the dummy that couldn’t find it, so I didn’t post anything. I figured this was about private equity involvement, but saw nothing mentioned on their site.
I want my fair share
[Re: SomeCarGuy]
#3121733
02/15/23 01:34 PM
02/15/23 01:34 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Should I be using an RTV or other sealant with the Milodon oil pan gasket set?
[Re: larrymopar360]
#3121783
02/15/23 04:18 PM
02/15/23 04:18 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
for the gaskets, all you need is a small dab of RTV at the four intersecting corners.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#3121841
02/15/23 07:51 PM
02/15/23 07:51 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I know sometimes less is best but I've not had good experiences sealing small block Mopars especially rear mains. I'll have to see if builder used sealant anywhere but corners. I don't suppose a thin layer around the rest would hurt though.
[Re: larrymopar360]
#3121900
02/15/23 10:45 PM
02/15/23 10:45 PM
Posts: 15,581 Omaha Ne
TJP
Omaha Ne
I know sometimes less is best but I've not had good experiences sealing small block Mopars especially rear mains. I'll have to see if builder used sealant anywhere but corners. I don't suppose a thin layer around the rest would hurt though. In a perfect world it shouldn't be needed, but an ounce of prevention - - - , I also let the sealer set for 24 hours before use. A lot fewer issues with minor leaks like rear ends. I had a strange one a few years back, fresh build by a local shop. had a leak midway back on the pan rail. When the pan was dropped the gasket was stuck to both surfaces yet leaked as though there was a void in the middle of the gasket. STRANGE ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: TJP]
#3133960
03/31/23 03:30 PM
03/31/23 03:30 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Always want to followup for those who may encounter similar issues. Took me longer than expected to pull pan.
What I found; dipstick indeed too short! Barely passes windage tray and only by maybe half inch if that much. Builder did not use gasket at back of pan, just filled with sealant. Obviously manufacturer defect and uneven surfaces to work with so now I have to trim the gasket to fit surface. Also going to find a longer dipstick
[Re: larrymopar360]
#3133965
03/31/23 03:34 PM
03/31/23 03:34 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm not blaming Muscle Motors who built it because I'm sure they got parts this way and were fighting a schedule. AND otherwise super happy with engine. It runs super strong. Insides were VERY clean.
[Re: larrymopar360]
#3133969
03/31/23 03:53 PM
03/31/23 03:53 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just called milodon tech line and told him my problem and I barely finished and he spouted out "you need dipstick 22220". Wow he sure had that part number handy without even thinking twice! If that's the one I need then why in hell did you tell me 22060 before? I just ordered it on Summit for $30
[Re: Stanton]
#3134007
03/31/23 06:42 PM
03/31/23 06:42 PM
Posts: 43,386 Bend,OR USA
Cab_Burge
You only need a dipstick long enough to read "full" Not me ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I want to know when to add oil, not only when it is full ![work work](/ubbthreads/images/graemlins/custom/work.gif)
