Re: Bearings for Molnar crank
[Re: fastmark]
#3120152
02/09/23 07:30 AM
02/09/23 07:30 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I just chamfered my big block bearings with a burr.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: dvw]
#3120185
02/09/23 10:10 AM
02/09/23 10:10 AM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
Clevite MS1266HG is what you are looking for if running a 360 sized main. Doug 340 mains
[Re: fastmark]
#3120195
02/09/23 11:23 AM
02/09/23 11:23 AM
Posts: 9,835 MI, usa
dvw
MI, usa
MS540H 1/2 groove. MS540HK 1/2 groove coated Personally I prefer the 1/2 groove. They feature more surface area in the loaded posistion. It looks like 360 main are full groove only. 340 main are 1/2 groove only Read this from Clevites tech page. Doug
Various forms of main bearing grooving have been used over the years. We are frequently asked what difference grooving makes. First, it’s essential to understand that bearings depend on a film of oil to keep them separated from the shaft surface. This oil film is developed by shaft rotation. As the shaft rotates it pulls oil into the loaded area of the bearing and rides up on this film much like a tire hydroplaning on wet pavement. Grooving in a bearing acts like tread in a tire to break up the oil film. While you want your tires to grip the road, you don’t want your bearings to grip the shaft. The primary reason for having any grooving in a main bearing is to provide oil to the connecting rods. Without rod bearings to feed, a simple oil hole would be sufficient to lubricate a main bearing. Many early engines used full grooved bearings and some even used multiple grooves. As engine and bearing technology developed, bearing grooving was removed from modern lower main bearings. The result is in a thicker film of oil for the shaft to ride on. This provides a greater safety margin and improved bearing life. Upper main shells, which see lower loads than the lowers, have retained a groove to supply the connecting rods with oil. In an effort to develop the best possible main bearing designs for performance engines, we’ve investigated the effects of main bearing grooving on bearing performance. The graphs illustrate that a simple 180 degree groove in the upper main shell is still the best overall design. While a slightly shorter groove of 140 degrees provides a marginal gain, most of the benefit is to the upper shell, which doesn’t need improvement. On the other hand, extending the groove into the lower half, even as little as 20 degrees at each parting line (220 degrees in total), takes away from upper bearing performance without providing any benefit to the lower half. It’s also interesting to note that as groove length increases so do horsepower loss and peak oil film pressure which is transmitted directly to the bearing.
[Re: dvw]
#3120396
02/10/23 06:34 AM
02/10/23 06:34 AM
fastmark
Abilene, Texas
Hmm. That’s an interesting read on a commonly discussed topic here. I guess if that is what the people think that make the bearings, I should pay attention. Thanks for the information.
[Re: Hot 340]
#3120412
02/10/23 09:31 AM
02/10/23 09:31 AM
dvw
MI, usa
[quote} Theories are good but how often have you seen a lower that was bombed out because you KNOW it was load bearing insufficiency. Maybe in severe hp applications. I'll take full time rod oiling. [/quote]
My take. My race motor runs 3/4 groove. Has close to 850 passes. 4.5" stroke@7300. There was one issue when we bent the pan and broke a windage tray injuring a rod bearing. Every other rod bearing that has been removed has looked like new. Though it's never hurt a main a few have certainly not looked like new. Especially #4. Same on my sons turbo small block. Rods are always nice. Mains not as good. As far as theory. I would bet the bearing manufacturer knows just a little bit more about bearings than any of us. Doug
[Re: SportF]
#3120413
02/10/23 09:32 AM
02/10/23 09:32 AM
Posts: 3,395 Pa
Hot 340
Pa
I don't think this is a theory. This is either the same, or similar info that came out of a Chrysler dyno study years ago. We can't see the graph here, but not a lot of graphs are simply made up, they are results on paper. Both full and partial grooves have been around a long time, and both work. One maybe better than the other. I know what you are saying. Wrong choice of words in my part. I am sure big hp applications it's an issue. But in lower hp it might as well be a theory
