Re: Members with 4 wheel disc systems: Can you lock yours up ?
[Re: ruderunner]
#3121183
02/13/23 03:05 PM
02/13/23 03:05 PM
Posts: 6,335 nowhere
Sniper
nowhere
To clarify, Mustang calipers have the parking brake. Explorer do not, crown vic do not, F150 do not. Ah, my misunderstanding. No sure why you decided to throw that tangent into the conversation though.
[Re: Sniper]
#3121200
02/13/23 03:36 PM
02/13/23 03:36 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
On a related note, the Dr Diff 10.75" rear disc setup ... which allows the factory and most preferred tapered axle bearings (and using whatever Mustang calipers)... does NOT allow clearance of the factory sway bar end links... therefore... you have to change the sway bar to an under-axle-design. That was a big surprise... I discovered it the hard way.. Cass confirmed (I wish it was indicated in his description of the setup). I had to remove my custom 1" factory-shaped upper sway bar... purchased a Helwig 7/8" (three point adjustable) under axle sway bar... a bit of a hassle to install ... but satisfying when all done (plus the purchase price.. fortunately, Summit had it in-stock and I recvd it in a cpl days).
Using the Cordoba 11.75" front rotors and factory calipers, along with the Dr Diff 10.75" rear discs, I cannot lockup the rears... only the fronts under severe braking... so far, relatively satisfied. I installed an adjustable proportioning valve... I leave it completely open... no bias needed towards front or rear... I could've probably not even bothered with that install.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#3121207
02/13/23 04:10 PM
02/13/23 04:10 PM
Posts: 275 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Forgot to mention I have a proportioning valve to the rear brakes but I have never adjusted it, it’s wide open also. Pad material has had the greatest effect for me
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: moparx]
#3121526
02/14/23 06:24 PM
02/14/23 06:24 PM
metallicareload
Anchorage, Alaska
97 SVT Cobra Mustang shows a 1” master cylinder with hydroboost
[Re: AndyF]
#3136879
04/10/23 02:54 AM
04/10/23 02:54 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I've had multiple issues with the Cobra calipers on the rear of my Coronet. I've had to replace the calipers a couple of times when they fail to work properly. Not sure why I've had such bad luck with them, they seem to work fine in an OEM application. But when they get out of adjustment they will really reduce braking ability. This is interesting. I somehow missed this when you first posted it. A former Moparts member that is on FABO and FBBO mentioned that these Ford calipers have some weird quirks. Like what Sniper wrote, the parking brake ties into the caliper performance. I've read that the parking brake needs to be pressed and released several times to take up slack that forms as the pads wear. Failing to do so results in greater pedal travel before the brakes engage. In addition to all of this, since 2001 I've used this '75 Dart single diaphragm brake booster:
[Re: racerjoe]
#3139758
04/21/23 01:49 PM
04/21/23 01:49 PM
Kern Dog
Granite Bay CA
FWIW, locking brakes doesn't decrease your stopping distance. I know that. MY point was that if I'm not able to lock the brakes, I don't know if they are working to their full potential. If I could lock them, I'd know where that point of lock up is and brake up to just below that point. Think of it like a throttle cable that isn't adjusted to allow full carburetor throttle blade opening. You could be driving around with a maximum of 3/4 throttle and not making the most power available.
[Re: Pacnorthcuda]
#3139780
04/21/23 03:24 PM
04/21/23 03:24 PM
metallicareload
Anchorage, Alaska
Pad material seems to have a big effect. My Just Suspensions front brake kit shipped with some dusty pads that were borderline scary when cold, and I don’t recall being able to lock em up. Carbon metallic pads installed last summer, less dust, ok when cold, and they do lock up
[Re: Sniper]
#3140748
04/25/23 10:27 PM
04/25/23 10:27 PM
Kern Dog
Granite Bay CA
A guy that was a respected member of this board, who is now posting at FBBO instead, said that the Mustang rear calipers need to be adjusted periodically. He said that sometimes the caliper pistons don't move out as the pads wear and that slack creates longer pedal travel. Because of this, I pressed the parking brake pedal almost 20 times yesterday before going for a drive. The pedal travel was the best that it had ever been and I thought that I had stumbled upon the FIX for it all. No, I did not. Within a few miles, the pedal travel increased.....then the travel was long enough to trigger the warning light. The front reservoir was almost dry. The rearmost reservoir had about 1/2" of fluid in it. I haven't checked the level in a few months but I found no leaks anywhere. I went ahead and set up the Motive self bleeding tank and set to bleed the right rear corner first. I always slip some clear surgical tubing over the bleeder nipple with the other end into a bottle, all to contain the fluid and to minimize the mess. Clear fluid started coming through which was unexpected. I'm using DOT 5 fluid now. I guess when I bled the system last time, I didn't notice and didn't bleed it long enough to get all the DOT 3 out. Mixed fluids can result in a mushy pedal. I was getting inconsistent pedal feel for awhile. One time the pedal would have good feel, other times it might feel mushy. It was not confidence inspiring. Out on the road, pedal feel is even and consistent now. The pads bite better once they warm up. I still can't get them to skid but they do slow the car down nicely. It is in no way dangerous, just not awesome. I may need to do some stops next to a modern car to see if they are comparable. If I'm on par with the Wife's car, I'll be impressed.
![Name: IMG_2050.JPG
ID: 483978 IMG_2050.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/483978/filename/IMG_2050.JPG)
[Re: Kern Dog]
#3142737
05/05/23 08:44 PM
05/05/23 08:44 PM
Posts: 5,960 ohio
ruderunner
ohio
You keep mentioning booster or some other forms of assistance.
Can you lock them up manually? Maybe get your 6'8" neighbor to drive the car and stomp the pedal.
Assistance or not, if you press the pedal hard enough, it should lock up.
Angry white pureblood male
