3/8 or1/2 oil pickup tube big block 6500 rpm street ???
#311809
05/08/09 03:37 PM
05/08/09 03:37 PM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
Looking for some opinions on the nesesity of changing to a 1/2 pickup. aprox 550 horse stock apearing b engine 6500 rpm max would like to keep the stock pan look. not to mention ground clearance i now have the stock baffeled hp pan, pickup. Thought of building a 1/2 pickup to fit pan not shure if it will empty the stock pan.
ACCELERATION SPECIALIST
Re: 3/8 or1/2 oil pickup tube big block 6500 rpm street ???
[Re: voigtspeed]
#311812
05/08/09 04:50 PM
05/08/09 04:50 PM
Posts: 5,080 organ
maximum entropy
organ
i had a 1/2 pickup and ended up breaking the boss in the block (stroker). i had to go to an external pickup. i've heard the milodon 3/8 pickups are as big or nearly as big as the 1/2". that's what i'm putting in my latest build.
[Re: cudarex]
#311813
05/08/09 04:57 PM
05/08/09 04:57 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Wouldn't go to a 1/2" pu with a stock pan. Will suck it dry.
wouldnt that say you need a bigger pan?no matter the size pickup your barings/clearances only allow so much oil to go by. ?
[Re: blownzoom440]
#311814
05/08/09 05:43 PM
05/08/09 05:43 PM
voigtspeed
merrill, wisconsin
Clearances are .002-.0025 rod side clearance also within stock specs. would like to keep the stock pan sleeper look. most engines that i have built whith this power or more i went 1/2 inch pickup but i have built 400 horse 5500 rpm motors with stock pickup and no issues actualy i have never had a bearing failure in a big block just want to get some opinions to feel safe car will no doubt get ran hard. thanks again
[Re: Steve1118]
#311816
05/08/09 06:04 PM
05/08/09 06:04 PM
Posts: 30,490 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
You will be fine with a 3/8 pickup.
x 2 ..... UNLESS you plan on running 6500 non-stop and for extended periods of time.
[Re: dOc …]
#311817
05/08/09 07:03 PM
05/08/09 07:03 PM
3/8 and you will have no problems based on all the thrashing I have done on BB's ( I have melted enough slicks to start my personal off shore reef )and have never ever had any trouble--the 1/2 in mod is not done right by most shops--you have to tap that hole pretty deep--if you don't the 1/2 in pick up will only go in a few threads and that IS trouble--You always take a chance of cracking the block and making a mess--just run a std pipe and let it rip--Good luck!
[Re: voigtspeed]
#311819
05/08/09 11:55 PM
05/08/09 11:55 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I have built many motors with both size pick ups, I prefer using the 3/8 in the blocks that came with them instad of machining and tapping for the 1/2. My 518 C.I. low deck stroker in my street/strip Duster uses a stock Mopar 1970-71 street Hemi/6 pak oil pan and the stock Mopar 440 six pak 3/8 pick up I shift the motor at or above 7000 rpm at the track, over three hundred runs with that system so far and no evidence of oil starvation so far. I oil the Harland Sharp roller rockers full time and the bearing clearances are loose, .003+ on both rods and mains. I also use real thin oil, 5W20WT so maybe it runs back into the pan faster than the thicker oils will I do use the stock windage tray and a custom made cranksahft oil scraper also
[Re: Cab_Burge]
#311820
05/09/09 07:50 AM
05/09/09 07:50 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
3/8ths will be just fine.We've never used the 1/2 inch pickup,and have never had bearing problems.
[Re: voigtspeed]
#311821
05/09/09 08:41 AM
05/09/09 08:41 AM
Posts: 16,932 NC
440Jim
NC
Although I like the 1/2 NPT mod done correctly, you should be fine with a 3/8" NPT pickup in your application. That being said, there are a lot of other things in the oiling system than just the pickup: the pan and baffles, oil capacity, drain back, pump volume, oil passage mod, rocker oiling, windage tray, etc. are just some.
As mentioned, using a 3/8" thread welded to a larger tube to the pickup point gets some benefit without modifying the block. a.k.a. Milodon
[Re: 440Jim]
#311822
05/09/09 09:07 AM
05/09/09 09:07 AM
voigtspeed
merrill, wisconsin
Thanks for all the input i thought 3/8 would do the job just looking for a little reashurance i guess sometimes its hard to draw the line. Thanks much moparts!!
