Re: Balancing problems with an old KB Top Fuel stroker crank
[Re: EchoSixMike]
#3116925
01/27/23 04:12 AM
01/27/23 04:12 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
They said yesterday that they needed to add 12 ounces to it, 6 ounces on each end. It has a bunch of Mallory metal in it already.. I'll weigh the steel H beam rods when they return all the parts and then weigh some Carrillo aluminum rods I have on the shelf and see how weight difference there is between the two and go from there. I'll, hopefully, use that cranks and rods on another build later once I figure out how to use it without having to spend a bunch more money on it to use that crank and rods
[Re: EchoSixMike]
#3116957
01/27/23 09:34 AM
01/27/23 09:34 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
That doesn't make any sense to me. What is the bob weight of the current parts going into it? 12 oz, ie 12x28gm add? That's preposterous. With heavy metal already in the crank? Not adding up? S/F....Ken M ^^^^This^^^^ I have done a few old fuel cranks, the last one was a center counterweight and I had to remove 512 grams, it made me sick to drill into the heavy metal. I can't imagine adding weight to a heavy crank. Do you have the bob weight numbers? Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3117023
01/27/23 12:34 PM
01/27/23 12:34 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Sure dont sound right to me, maybe have someone else check it.
[Re: Al_Alguire]
#3117037
01/27/23 01:08 PM
01/27/23 01:08 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: HardcoreB]
#3117839
01/31/23 01:02 AM
01/31/23 01:02 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I would get a second opinion. Good idea to go with plan B and order a 440 Source crank.
[Re: FastmOp]
#3117920
01/31/23 03:02 PM
01/31/23 03:02 PM
Cab_Burge
Hemi bore on a fuel car is 4.187 or so. Cab is prolly building a 4.5 bore for what he's wanting to do. . Your correct: up: I'm using aa Icon shelf piston on this KB block B1 headed 572 C.I. motor that I'm building for NOS. These Icon pistons have a raised dome along with heavier wall .990 wrist pins for the NOS so maybe those pistons are heavier than the smaller bore Hemi pistons weighed I'll try and use that crank and possibly rods on another wedge build later this year
[Re: HardcoreB]
#3118114
02/01/23 02:29 PM
02/01/23 02:29 PM
Cab_Burge
Both cranks are at the machine shop, I'm hoping to get both back this month and start mocking up the 572 parts I'm debating on having a cam reground or use the solid roller cam I bought from Koffels years ago for a N/A B1 motor I'm planning on spraying it with NOS from 150 hp up to 450 HP
