Dingy '04 Ram 1500 #3116665
01/26/23 10:09 AM
01/26/23 10:09 AM
Tulsa, Oklahoma
Wagonmaster Offline OP
Tulsa, Oklahoma
Key out of switch, all wires to switch disconnected, the chime will not cease! Discuss...
Re: Dingy '04 Ram 1500 [Re: Wagonmaster] #3116724
01/26/23 01:38 PM
01/26/23 01:38 PM
moparx Offline
moparx  Offline
i'm thinking the key-in-switch chime is BCM activated, and has a two wire connector that is not part of the ignition switch circuit.
just guessing here, with only minivan wiring experience to the 2007 model year. the diagnostic tree for that symptom in those suggest a short to ground or the BCM malfunctioning by not seeing or recognizing the key out circuit.
i believe the ram may be similar wiring circuitry. shruggy
beer
