Big block header gasket question #3116164
01/24/23 09:10 PM
01/24/23 09:10 PM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
I have a new pair of Trick Flow 240's and held up the Taylor multi layer aluminum header gaskets I bought against the exhaust port side of the head. The gasket overhangs each port to some extent, and the end ones by a good 3/16". So I buy a pair of Trick Flow big block Mopar header gaskets, and its the same thing. Just to be clear, the Trick Flow header gaskets do not match the exhaust ports on the Trick Flow heads. So I check the gaskets that came with my TTI headers and they are a perfect fit. I realize I have other options, but I was really wanting to use a multi layer copper/steel/aluminum gasket as I have had such good luck with them in the past. Can anyone recommend a brand that will actually fit correctly? Is there something I'm missing here? I have attached a couple of pictures to show what I am talking about. Thank you for any and all help.
Re: Big block header gasket question [Re: IROC78] #3116173
01/24/23 09:32 PM
01/24/23 09:32 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
have you tried flipping them over
Re: Big block header gasket question [Re: CSK] #3116179
01/24/23 09:44 PM
01/24/23 09:44 PM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
Oh yes I'm sorry I forgot to mention I tried them in all possible orientations, and they appear symmetrical as there was no difference in fitment.
Re: Big block header gasket question [Re: IROC78] #3116195
01/24/23 10:33 PM
01/24/23 10:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check out remflex gaskets.
Re: Big block header gasket question [Re: rickraw] #3116203
01/24/23 10:50 PM
01/24/23 10:50 PM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
Excellent I will do that. Thank you!
Re: Big block header gasket question [Re: rickraw] #3116279
01/25/23 06:00 AM
01/25/23 06:00 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
That's what I use on the big block Dart GTS with fenderwell headers. up
Re: Big block header gasket question [Re: SNK-EYZ] #3116340
01/25/23 08:16 AM
01/25/23 08:16 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd run it. Ain't no flow over there anyway.
Re: Big block header gasket question [Re: FastmOp] #3116396
01/25/23 01:11 PM
01/25/23 01:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: Big block header gasket question [Re: IROC78] #3116448
01/25/23 03:43 PM
01/25/23 03:43 PM
Trim as needed wrench up scope twocents
Re: Big block header gasket question [Re: Cab_Burge] #3116518
01/25/23 07:00 PM
01/25/23 07:00 PM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
Thank you for the replies I really appreciate the suggestions. I was just really surprised that one company would make two products to be used in conjunction with one another and this was the result. The Trick Flow ones are definitely going back to Summit as I just bought them. Thanks again!
