Page 1 of 5 1 2 3 4 5
Hemi ray barton valve covers in e body #3115781
01/23/23 07:09 PM
01/23/23 07:09 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anyone have a hemi e body with the ray barton valve covers? If so, do they hit the inner fenders? Originally I had a small block k member with the Schumacher conversion mounts and now I have a hemi k member conversion from Al Debevec and the passenger side valve cover hits the inner fender and blower motor with both setups. Any trick to getting it to fit without denting the inner fender?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3115783
01/23/23 07:41 PM
01/23/23 07:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
B-Body can have some of the same problems. There is a special right side cover that Indy makes Did you check with Barton?
Re: Hemi ray barton valve covers in e body [Re: NITROUSN] #3115788
01/23/23 07:57 PM
01/23/23 07:57 PM
clarks summit pa
clarks summit pa
He told me that he hasn't had any issues and that they fit. However, I have had nothing but issues with the motor since I bought it and they have been zero help , so I'm not sure if they're just saying they fit fine.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3115800
01/23/23 08:55 PM
01/23/23 08:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a pair of Barton covers on my mock up display Hemi in the Racement (racing themed basement), but never used them to mock up in my B Bodies or E Body. I do have the tapered passenger Indy covers on my Hemi in my E Body. They do give you any extra clearance that you may need. If you look closely you can see the tapered section in the center.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3115804
01/23/23 09:10 PM
01/23/23 09:10 PM
AndyF Offline
AndyF  Offline
If they don't fit then they don't fit regardless of what the mfg tells you. Believe your own eyes not what the sales guy says.
Re: Hemi ray barton valve covers in e body [Re: AndyF] #3115814
01/23/23 09:30 PM
01/23/23 09:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
i would expect a little more from Barton BUT I cannot count the number of time in the last 25 years I have been told I WAS THE ONLY ONE HAVING THE PROBLEM whistling
I actually NAILED Hooker headers on newly designed BB corvette side pipes that didn't fit. SOS as above. Caught them on a corvette forum wanting an original BB car to check side pipe fitment. They did compensate me quite well wink
If other have had the same issue I would suggest collecting some info and going to Ray himself twocents keep us posted beer
Re: Hemi ray barton valve covers in e body [Re: TJP] #3115832
01/23/23 10:23 PM
01/23/23 10:23 PM
clarks summit pa
clarks summit pa
Here are some pictures of the clearance issues. They're not even close to fitting.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3115838
01/23/23 11:05 PM
01/23/23 11:05 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
They are thick enough castings that you could mill/clearance them to fit and re-wrinkle paint.
Re: Hemi ray barton valve covers in e body [Re: 6PKRTSE] #3115871
01/24/23 04:09 AM
01/24/23 04:09 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Didn't the 64-65 Hemi cars modify the shock tower for clearance? I think they cut it out and flipped it over or something?
Re: Hemi ray barton valve covers in e body [Re: bobby66] #3115916
01/24/23 07:57 AM
01/24/23 07:57 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If my memory serves me correctly on the two I have installed, they both took special mods. These were stage V valve covers but they are probably the same. We used the stock k frame on both of these cars. One had Arruzza mounts. It was a 68 charger. All we had to do to it was put a 1/4” steel plate spacer between the rubber and the steel mount. It cleared. The e body had Schumacher mounts and the first one did not come close. He called Schumacher and they had a special mount to raise the right side. It still may have taken a spacer, I’m not sure. I’ve got a picture on my phone I’ll try and post. The 65 SS cars had a right side shock tower that was modified and recessed right at the point wher the shock bolts to the tower. The valve covers cleared, you just could not pull them off for the tech inspector at the track. I know you said you have a hemi k frame but my point is you will have to space the right side higher in order for it to fit. This picture is after the mod. I don’t have a picture of the valve cover but it was about the same.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3115994
01/24/23 12:52 PM
01/24/23 12:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What kind of issues are you having with the engine?
Re: Hemi ray barton valve covers in e body [Re: 6PKRTSE] #3116004
01/24/23 01:11 PM
01/24/23 01:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
might also be able to cut for clearance on the Valve cover and fill with a small section round tube or curved flat stock. Would have to make sure there was no inside interference which is doubtful beer
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3116005
01/24/23 01:12 PM
01/24/23 01:12 PM
CrazyD Offline
CrazyD  Offline
Were you able to get the driver's side insulator to sit flat? I recall you reported that issue last Fall.
Re: Hemi ray barton valve covers in e body [Re: CrazyD] #3116032
01/24/23 02:12 PM
01/24/23 02:12 PM
moparx Online content
moparx  Online Content
there is no such thing as a "bolt on part". biggrin
beer
Re: Hemi ray barton valve covers in e body [Re: moparx] #3116034
01/24/23 02:27 PM
01/24/23 02:27 PM
an8sec70cuda Offline
FWIW...I have the Indy valve covers on my hemi...not the ones w/ the clearance notch built into them. I heated and clearanced the inner fender near the shock stud w/ a BFH. I removed the heater & blower motor assembly years ago, so I can't comment on clearance there.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi ray barton valve covers in e body [Re: 71birdJ68] #3116096
01/24/23 05:24 PM
01/24/23 05:24 PM
clarks summit pa
clarks summit pa
The engine only has 150 street miles on it, zero track time or full throttle blasts and absolutely no beating on the car, and it has already had 6 different rear mail seals installed in it, 4 by me and 2 by Ray himself, 2 different real main seal retainers, and it just pours oil to the point it can't even be driven. Tons of blowby coming out of the breathers , 2 different sets of piston rings installed in it, same issues and this was all at my expense on a brand new engine. I told them I still have the same issues after pulling out the engine 3 different times and going back and forth all the way to their shop just to basically be told tough luck. If you would like to know more about it, I can PM you details. I don't want it to look like a post about me bashing someone or a company.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3116097
01/24/23 05:28 PM
01/24/23 05:28 PM
Lots of places are having issues getting rear main seals to not leak. Guess it's just poor quality seals. Not taking up for Ray, just saying.
Sorry to hear you've had so much trouble w/ it. I know it sucks after making such an investment.
CHIP
Re: Hemi ray barton valve covers in e body [Re: CrazyD] #3116098
01/24/23 05:29 PM
01/24/23 05:29 PM
clarks summit pa
clarks summit pa
I've been real busy with work, so I haven't had time in the past couple of months to work on it. I'm finally getting back around to it now, but no, the drivers side still sits up about 3/8" to 1/2" off of the k frame. Even if I get this to drop down all of the way, I still don't think it'll be enough to correct the passenger side. I initially considered adding a spacer between the mount, but started to wonder if it would cause any drive train alignment issues since the motor would be shimmed up on the one side. I'm wasnt sure if it would affect the transmission or driveline angle since technically the whole assembly would now be raised on the one side.
Re: Hemi ray barton valve covers in e body [Re: 73cuda340] #3116104
01/24/23 05:43 PM
01/24/23 05:43 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I was wondering who's block he used in the build.
Re: Hemi ray barton valve covers in e body [Re: 71birdJ68] #3116122
01/24/23 06:47 PM
01/24/23 06:47 PM
clarks summit pa
clarks summit pa
World aluminum block
