T/A 392 Challenger Test&Tune
#3114967
01/20/23 07:20 PM
01/20/23 07:20 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Made it to the Test & Tune bone stock 392 Challenger with Drag Radials Race weight 4445 OUCH Wallace Calculator
MPH 114.45 513 hp ET 11.79 536 hp
Re: T/A 392 Challenger Test&Tune
[Re: Smoparmike]
#3116022
01/24/23 01:53 PM
01/24/23 01:53 PM
Posts: 4,710 Florida
BDW
Nice 60, How did you launch?
[Re: BDW]
#3116048
01/24/23 03:11 PM
01/24/23 03:11 PM
CSK
Pattison Texas
I used the launch control @ 2400rpm
[Re: moparx]
#3116836
01/26/23 07:22 PM
01/26/23 07:22 PM
CSK
Pattison Texas
I used the launch control @ 2400rpm using that, what does the converter flash to ? [or am i forgetting your car is a stick ?] Its an auto, not sure how high it flashes.
[Re: CSK]
#3116879
01/26/23 10:37 PM
01/26/23 10:37 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I used the launch control @ 2400rpm I have that on mine but have never figured it out, walk me thru it please. My 15 SRT spun for 30 ft before just letting out then on it easy, went 13.02 105
[Re: cudaman1969]
#3116904
01/27/23 12:22 AM
01/27/23 12:22 AM
CSK
Pattison Texas
I used the launch control @ 2400rpm I have that on mine but have never figured it out, walk me thru it please. My 15 SRT spun for 30 ft before just letting out then on it easy, went 13.02 105 Not sure if the 2015 has the same thing ? in the settings on the screen press launch control & set it to the rpm you want , then when ready to use it there is a LC button under the A/C controls, hit the button & in the center of the dash it tells you, push hard on brake push accelerator to the floor very fast & hold,, when letting go of the foot brake the car goes
[Re: CSK]
#3117066
01/27/23 01:59 PM
01/27/23 01:59 PM
cudaman1969
fredericksburg,va
I used the launch control @ 2400rpm I have that on mine but have never figured it out, walk me thru it please. My 15 SRT spun for 30 ft before just letting out then on it easy, went 13.02 105 Not sure if the 2015 has the same thing ? in the settings on the screen press launch control & set it to the rpm you want , then when ready to use it there is a LC button under the A/C controls, hit the button & in the center of the dash it tells you, push hard on brake push accelerator to the floor very fast & hold,, when letting go of the foot brake the car goes Thanks for info I’ll try that. I can set it up to 3500 rpm but then couldn’t get the procedure in my thick head, I was thinking pushing and then releasing like the trans brake on race car.
[Re: CSK]
#3117318
01/28/23 05:42 PM
01/28/23 05:42 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Very nice! It would be a VERY close match for my 5090 lb pig. It would come down to your 60' vs my mph.
[Re: feets]
#3117319
01/28/23 05:45 PM
01/28/23 05:45 PM
CSK
Pattison Texas
Very nice! It would be a VERY close match for my 5090 lb pig. It would come down to your 60' vs my mph. Very COOL, that would be a great race, hope all is going well for Y'all
[Re: BDW]
#3117342
01/28/23 08:25 PM
01/28/23 08:25 PM
CSK
Pattison Texas
4445 lbs, is that with you in the car? Some serious HP to push that Yes with me in it & about 1/3 tank of fuel
[Re: BDW]
#3117376
01/28/23 10:20 PM
01/28/23 10:20 PM
feets
Senior Management
Senior Management
Irving, TX
4445 lbs, is that with you in the car? Some serious HP to push that Today's high gear count transmissions make massive improvements in performance. The number of Mustangs out there really put a point on it. The 5.0 Mustangs used to hang in there with my CL65 up to 60 mph or so then start dropping back. The 10 speed cars have the same output but they hang in there till around the 1/8 mile before losing ground. The longer they have to pull a gear the more I pull on them. Dropping the 8 speeds behind the hemi made a significant difference, too. Granted, my car is a torque monster that has little problem pulling the 5 speed but wish I could get my hands on S65 coupes with the 7 speed to see how they compare to mine.
