Testing Results and Air Shifter Question #3112901
01/17/23 03:39 PM
01/17/23 03:39 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I went to a private track rental this past weekend and did some testing. Best was 1.37 60ft and 6.19@109 on 15 lbs of boost. AFR seemed a little fat at 10.9 to 11.2, but not bad, though I may lean it out a tad...have to think about it. Made a change to run 17 lbs of boost and the AFR was way rich (mid 10's). I should have taken a closer look at the logs while there and made a change and 1 more pass but decided to stop at that point.
What are you guys running for an air shifter for a 727? What is the total price for everything?
Re: Testing Results and Air Shifter Question [Re: TheOtherDodge] #3112909
01/17/23 04:09 PM
01/17/23 04:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Buddy of mine finally scrapped his Turbo action shifter with air, to a PPP air shifter. No complaints, and now it works every pass, unlike the old TurdAction shifter.
69 GTX 68 Road Runner
Re: Testing Results and Air Shifter Question [Re: JERICOGTX] #3112914
01/17/23 04:24 PM
01/17/23 04:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had an air PPP on my 727 and now I have electric on my PPP powerglide.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Testing Results and Air Shifter Question [Re: JERICOGTX] #3112932
01/17/23 05:20 PM
01/17/23 05:20 PM
A727Tflite Offline
A727Tflite  Offline
wrong info
Re: Testing Results and Air Shifter Question [Re: A727Tflite] #3112965
01/17/23 06:50 PM
01/17/23 06:50 PM
gregsdart Offline
gregsdart  Offline
I have run a co2 shift solenoid, (ACD?) on a B &M ratchet shifter since 2002. Flawless. Just make sure you have CO2!
Re: Testing Results and Air Shifter Question [Re: gregsdart] #3112967
01/17/23 06:56 PM
01/17/23 06:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What is the air and solenoid stuff you speak of? It must have something to do with that trans brake dohickey.
Doug
Re: Testing Results and Air Shifter Question [Re: dvw] #3112975
01/17/23 08:00 PM
01/17/23 08:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am having a new PPP air shifter with clean neutral being built right now for my 64. They are not cheap but IMO the best and original one.
Re: Testing Results and Air Shifter Question [Re: Al_Alguire] #3113006
01/17/23 09:12 PM
01/17/23 09:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
WHEW!! was afraid the “repo” man was going to show up at my door!
My T/A cheatya out of a round shifter was truly an automatic shifter….. the force of launch would make the 1-2 shift on its own. Luckily for me the mopar guy creed got me good money on resale, and Al called me on a used PPP that fit my needs. I’d gladly pay full pop for a PPP after using one. It’s a great shifter.
Re: Testing Results and Air Shifter Question [Re: TheOtherDodge] #3113009
01/17/23 09:15 PM
01/17/23 09:15 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
….and I’ve got a shift timer I’d let go if you’re interested. ACD brand
Re: Testing Results and Air Shifter Question [Re: J_BODY] #3113048
01/17/23 10:41 PM
01/17/23 10:41 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Isn’t it funny how, since 1984, and mine hasn’t done the 1-2 deal. Biondo and Deadenbear both, USED to sell co2 shifters for T/A.
Re: Testing Results and Air Shifter Question [Re: Leigh] #3113079
01/18/23 12:44 AM
01/18/23 12:44 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have an old guy with old worn out TA shifters in both his cars. Has trouble with both of them. Won't let me replace them because he's an old guy. I hate the dumb things.
Re: Testing Results and Air Shifter Question [Re: CMcAllister] #3113080
01/18/23 12:47 AM
01/18/23 12:47 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yep, if something doesn’t work, replace it.
Re: Testing Results and Air Shifter Question [Re: dvw] #3113967
01/18/23 06:58 AM
01/18/23 06:58 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
Doug, I have no idea...
Re: Testing Results and Air Shifter Question [Re: Leigh] #3114042
01/18/23 07:16 AM
01/18/23 07:16 AM
PA
Harry's Taxi 2 Offline
PA
+1 since 1982 from 11 sec. cars to 8 sec. car
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Testing Results and Air Shifter Question [Re: J_BODY] #3114173
01/18/23 01:15 PM
01/18/23 01:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Jay I think have sold a dozen of them to folks over the years. I sold two at the MATS last year and guys were trying to beat me up on the price. I will have mine that is currently in the 64, it is red with no air and a clean N. I seem to come across them frequently from comp and SS guys.
Re: Testing Results and Air Shifter Question [Re: Leigh] #3114213
01/18/23 03:40 PM
01/18/23 03:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Well, yeah.
The 1-3 deal on the one with the air shift is just the beginning,
I much prefer the Hurst Quarter Stick with a cable upgrade or B&M Pro Stick if you don't want to spring for a PPP.
I've used a Pro Bandit style shifter on a two speed and liked it. Not sure how the B&M version is. Never looked at one.
Re: Testing Results and Air Shifter Question [Re: Al_Alguire] #3114214
01/18/23 03:43 PM
01/18/23 03:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
How is availability on those new right now? I may try to upsell my guy and put something decent in his cars.
Re: Testing Results and Air Shifter Question [Re: CMcAllister] #3114229
01/18/23 04:56 PM
01/18/23 04:56 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
It's best to contact Ben Holt, at John Holt Racecars. He somehow has the best inside track of ordering from PPP.
Re: Testing Results and Air Shifter Question [Re: dvw] #3114235
01/18/23 05:08 PM
01/18/23 05:08 PM
moparx Online content
moparx  Online Content
Doug
best shifter ever made in my humble opinion, is the "typewriter" [or versions thereof] like Doug has. up
beer
Re: Testing Results and Air Shifter Question [Re: dvw] #3114247
01/18/23 05:58 PM
01/18/23 05:58 PM
A727Tflite Offline
A727Tflite  Offline
Doug
Do you need a reverse lockout with the push buttons?
