Re: Calvert 90/10 shocks ?
[Re: ademon]
#3114238
01/18/23 05:18 PM
01/18/23 05:18 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I tried a set years ago. They were too loose for my mid 9 sec car and wouldn't allow it to hook.
[Re: an8sec70cuda]
#3114243
01/18/23 05:45 PM
01/18/23 05:45 PM
Posts: 4,693 Wichita
GY3
Wichita
It really depends on power level.
We have Competition Engineering 3 way and they work great at 90/10 for the 11.0 to 11.50 range. Extend quickly, get the front up and keep it there.
As we got faster than 11.0-ish, and deep into the 10's, the front would rise TOO quickly, wheelie a little and then come down too fast causing the rear to unload.
I have them at the 70/30 setting for the faster times and that seems to work better by slowing the extension. I updated the rears to Viking Crusaders but really need fronts and the Calvert rear/CE front combo seems to be getting the job done for now...
[Re: GY3]
#3114283
01/18/23 07:54 PM
01/18/23 07:54 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I have them at the 70/30 setting for the faster times and that seems to work better by slowing the extension. I updated the rears to Viking Crusaders but really need fronts and the Calvert rear/CE front combo seems to be getting the job done for now... I’m around 11.50. A body, small block, SS rear springs. Needed more fore street traction with drag radials.
[Re: an8sec70cuda]
#3114415
01/19/23 09:17 AM
01/19/23 09:17 AM
Posts: 2,930 A shed in England
Tig
A shed in England
I tried a set years ago. They were too loose for my mid 9 sec car and wouldn't allow it to hook. Same here, low 10's. One pass was enough for us to put our old c/e 3 ways back on. Though results may vary, I've seen lighter cars with less power run well with them. Personally I'd go to good d/a shocks from day one and not go through differing manufacturers looking for a good shock like I did. With a D/A you can change the settings to match what the car wants as you progress ET wise.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3114461
01/19/23 12:01 PM
01/19/23 12:01 PM
Posts: 4,457 Washington
madscientist
Washington
Save your money and buy something that is double adjustable.
IMO all those single adjustable shocks are worthless.
[Re: madscientist]
#3114536
01/19/23 04:19 PM
01/19/23 04:19 PM
Posts: 11,637 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Making it loose is easy. In the old days, guys would drill a small hole in the bottom and drain the oil. And put 6 cylinder springs in.
Controlling pitch rotation is harder. Putting it on the bumper and having it crash down and bounce 4 or 5 times is bad.
Your situation dictates how much money you need to spend on shocks.
[Re: madscientist]
#3115106
01/21/23 12:27 PM
01/21/23 12:27 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
IMO all those single adjustable shocks are worthless. Agreed! Spend the money once! Extending quickly is not always best!
