Re: Testing Results and Air Shifter Question [Re: dvw] #3114260
01/18/23 06:28 PM
01/18/23 06:28 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
TheOtherDodge- did it need the front tightened up via your thoughts in your launch vids from a few months back? It sounds like it's picked up a bunch and is more consistent now, that's really good news!
Originally Posted by dvw
What is the air and solenoid stuff you speak of? It must have something to do with that trans brake dohickey.
Doug
Same, I'm all confused at the nomenclature here. laugh2
I also like Jeff's shifter. Shouldn't 1-4 be in a vertical Z pattern? lol
Re: Testing Results and Air Shifter Question [Re: gregsdart] #3114282
01/18/23 07:50 PM
01/18/23 07:50 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted by gregsdart
I have run a co2 shift solenoid, (ACD?) on a B &M ratchet shifter since 2002. Flawless. Just make sure you have CO2!
Pro Ratchet ??? Any pics ?
TIA up
Re: Testing Results and Air Shifter Question [Re: A727Tflite] #3114292
01/18/23 08:21 PM
01/18/23 08:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Do you need a reverse lockout with the push buttons?
Suucchh.
Re: Testing Results and Air Shifter Question [Re: TheOtherDodge] #3114324
01/18/23 09:49 PM
01/18/23 09:49 PM
ky
68roadrunner Offline
ky
Ppp shifter with the digital delay rpm/time shift activator is the ticket
Clean neutral is very sweet, just pulled all my tqflite stuff out and sold, to put in glide
Re: Testing Results and Air Shifter Question [Re: Tig] #3114353
01/18/23 11:36 PM
01/18/23 11:36 PM
gregsdart Offline
gregsdart  Offline
TIA up
I drilled a hole in the shifter arm for the wolinoid to connect to.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Testing Results and Air Shifter Question [Re: dvw] #3114383
01/19/23 02:11 AM
01/19/23 02:11 AM
Doug
I know what that is boogie up
Hopefully my 1963 Sport Fury will be drivable next year luck wrench
Re: Testing Results and Air Shifter Question [Re: gregsdart] #3114412
01/19/23 08:56 AM
01/19/23 08:56 AM
Finland
Hessu Offline
Hessu  Offline
Finland
Re: Testing Results and Air Shifter Question [Re: gregsdart] #3114414
01/19/23 09:11 AM
01/19/23 09:11 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
TIA up
Originally Posted by Hessu
Home made air sifter from pro ratchet
[img]https://scontent.fqlf1-2.fna.fbcdn....E_8eo3rVQgyBLg2pzVVFp8Aw&oe=63CEFAB6[/img]
Thanks Guys up
Re: Testing Results and Air Shifter Question [Re: CMcAllister] #3114471
01/19/23 12:31 PM
01/19/23 12:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by CMcAllister
How is availability on those new right now? I may try to upsell my guy and put something decent in his cars.
This will be the third one I have ordered in the last 6 months. All have come fairly quickly. But he is a one man shop these days and stays really busy, also working on some new features on the shifters. I would agree if you do not have an "inside track" to use a dealer. He is much quicker to respond to dealers than individuals.
Re: Testing Results and Air Shifter Question [Re: Al_Alguire] #3115068
01/21/23 10:46 AM
01/21/23 10:46 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Thanks for everyone's input..but am a little confused....
What is the actual shifter, air shifter components needed? wave
I looked at PPP website and went through the options and it seems to be about $1,100 for everything. Does that sound right?
Re: Testing Results and Air Shifter Question [Re: TheOtherDodge] #3115089
01/21/23 11:33 AM
01/21/23 11:33 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Yes that sounds correct.
Re: Testing Results and Air Shifter Question [Re: 71Demon528] #3115104
01/21/23 12:25 PM
01/21/23 12:25 PM
Houston, Texas
Houston, Texas
Thanks! up
