Re: Refresh engine, now no start. [Re: rebel] #3093335
11/11/22 08:59 AM
11/11/22 08:59 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Please keep us up on your findings curios on what they are work
Re: Refresh engine, now no start. [Re: racerx] #3093548
11/11/22 08:25 PM
11/11/22 08:25 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Torque converter unbolted, no rocker gear, no plugs, 40lbs. Honestly, for new rings, this feels ok to turn over on the power bar. I'm using std tension oil rings in the Total Seal Plasma Moly series. I might start putting parts back on & testing the difference in drag. I have another engine, 7 years old, has nearly the same springs & thats 65lbs to turn over with the engine complete.
Re: Refresh engine, now no start. [Re: rebel] #3093637
11/12/22 03:12 AM
11/12/22 03:12 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Going with a problem with the cam after today's tests. At the long block stage, we put the rocker gear on one side & it took 105 lbs on the torque wrench to turn over. Removed that side & did the other bank & still had the same result. The cam bearings are good, I gave them a polish with the scotchbrite when I was cleaning the block. But I'm pulling the cam & going to get it checked for straightness. Although it spins easy, it didn't spin easily unassisted, I had put that down to a burr on the bearing from a lobe catching during installation. Stay tuned.
Re: Refresh engine, now no start. [Re: rebel] #3093726
11/12/22 02:58 PM
11/12/22 02:58 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
On the 485" stock block motor the shortblock rotating with 1/16 1/16 3/16 rings was less than 15lbs When i put the roller cam and rocker gear on WITH NO sparkplugs rotating was 75ftlbs and it didnt 'feel' right but all was good. After asking others I learned that was reasonable but yours did seem unreasonably high!
Re: Refresh engine, now no start. [Re: HardcoreB] #3094059
11/14/22 02:56 AM
11/14/22 02:56 AM
new zealand
matt426 Offline
matt426  Offline
new zealand
Put a50mm/2 or 75mm/2 cable on it and a big starter from Grimmer and you will be right.
Re: Refresh engine, now no start. [Re: matt426] #3094549
11/16/22 01:07 AM
11/16/22 01:07 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
You said it is firing at tdc on #1. But is it firing at tdc on #1 on the compression stroke?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Refresh engine, now no start. [Re: rebel] #3105278
12/24/22 04:23 PM
12/24/22 04:23 PM
Mo.
racerx Offline
racerx  Offline
Mo.
bump for this work any updates on it?
Re: Refresh engine, now no start. [Re: racerx] #3105526
12/25/22 07:37 PM
12/25/22 07:37 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Well, the engine got pulled & stripped & everything rechecked, & rechecked again. It rotates fine as a long block, but as soon as I connect the valve train, it goes bad. So I currently have some weaker valve springs in it & it turns over with the torque wrench at 62lbs, which is a lot better than 120lbs it did before. The motor is back in the car, just waiting for me to add all the accessories so we can restart it. I am hoping after I have done a few heat cycles & maybe a bit of public road rural driving, things will bed in a bit better & then I can up my spring pressure again. The springs I had in it were 640lb rated springs, I'm thinking I should drop this to 525lb rated springs. Only problem is, I have a set of them, but I recently put them into my other street/strip car. Its Summer downunder & seriously too hot to be in the shed during the day. Since we are past the xmas rubbish now, I'm guessing I'll spend the next 2 nights in the shed finishing everything off. watch this space.
Re: Refresh engine, now no start. [Re: rebel] #3105867
12/27/22 10:21 AM
12/27/22 10:21 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My junk is the same way with the valve trane hooked up. Sux to turn
Re: Refresh engine, now no start. [Re: rebel] #3105947
12/27/22 03:52 PM
12/27/22 03:52 PM
Murphy is messing with you, don't give up tsk wrench up grin
I would go back through the ignition side of the engine compartment wiring to make sure that the coil has voltage in both the run and start position on the ignition switch scope twocents
Let us know what you find out that fixes it, it will help others down the road up
Re: Refresh engine, now no start. [Re: Cab_Burge] #3106155
12/28/22 04:45 PM
12/28/22 04:45 PM
moparx Offline
moparx  Offline
i second what Cab posted. up
beer
Re: Refresh engine, now no start. [Re: moparx] #3106167
12/28/22 05:13 PM
12/28/22 05:13 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Progressing well, hopefully tonite I'll have the oil system primed & I can check for leaks while I'm sorting out the cooling system. Might even try to start her up if I'm lucky.
Re: Refresh engine, now no start. [Re: rebel] #3107291
01/01/23 05:53 PM
01/01/23 05:53 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
UPDATE; I got it to start last night with the weaker valve springs. Haven't been able to run for long as I now have 2x oil leaks. 1x was the rocker cover gasket, so I glued 2x new ones on last night. The other is the pressure side of my oil pump, Guess I'll need to remove & replace the O ring. Shops will be open tomorrow so I'll try n find a place that sells decent-quality O rings to repair. Don't you hate it when you can use something umpteen times, never an issue until the shops are shut & you can't just go get a replacement.
I've been working on another engine at the present point in time, so haven't had much time to dedicate to this motor.
Re: Refresh engine, now no start. [Re: rebel] #3107368
01/01/23 10:48 PM
01/01/23 10:48 PM
Glad you found and fix it, what was it?
Re: Refresh engine, now no start. [Re: Cab_Burge] #3107383
01/02/23 12:03 AM
01/02/23 12:03 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
[align:center][/align]
The only thing we changed is the valve springs, the set that's on there now were staunch flat tappet springs. I've fixed the valve cover gaskets, & tightened the oil pump connection to try & remedy the oil leaks & now....the starter motor is having issues. It's a fresh rebuild of a HD ministarter variety. So that's tonites job, pull it off & see what's wrong with it. Can't even jump start with the screwdriver on the terminals. Good grief, I must have p!$$£d off some witch last year & she has a hex on me.
Re: Refresh engine, now no start. [Re: rebel] #3113019
01/17/23 09:35 PM
01/17/23 09:35 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Finally solved my drama, bought a new 2kw starter motor, the big red one, now we start straight away. Not all mini starters are equal.
Re: Refresh engine, now no start. [Re: carnut68] #3113025
01/17/23 09:43 PM
01/17/23 09:43 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Originally Posted by carnut68
Try the old starter. Maybe the new one is junk
I'll leave this here.
America First!
Re: Refresh engine, now no start. [Re: carnut68] #3113030
01/17/23 09:54 PM
01/17/23 09:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 15-1 572 has been started with the same factory Mopar mini starter going on 11 years. Loos like the middle one in your pic. 310 seat / 805 open.
Doug
Re: Refresh engine, now no start. [Re: carnut68] #3113078
01/18/23 12:41 AM
01/18/23 12:41 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I did actually have a few spare starters, none of them had the urgs to spin as fast as the new one. I sent all my starter stock to my starter motor rep, he checked them all & said there was nothing wrong, but he did suggest the 2kw unit over all the 1.4kw units.
Re: Refresh engine, now no start. [Re: rebel] #3114172
01/18/23 01:11 PM
01/18/23 01:11 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The camshaft events play a role in how much loading is added or negated in rotating resistance. I'd personally put the springs necessary to control valve events on the motor and adjust other things around that 'obstacle'
