Re: Testing Results and Air Shifter Question
[Re: dvw]
#3114260
01/18/23 06:28 PM
01/18/23 06:28 PM
Posts: 8,192 Plymouth, MI
Blusmbl
Plymouth, MI
TheOtherDodge- did it need the front tightened up via your thoughts in your launch vids from a few months back? It sounds like it's picked up a bunch and is more consistent now, that's really good news! What is the air and solenoid stuff you speak of? It must have something to do with that trans brake dohickey. Doug Same, I'm all confused at the nomenclature here. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) I also like Jeff's shifter. Shouldn't 1-4 be in a vertical Z pattern? lol
[Re: gregsdart]
#3114282
01/18/23 07:50 PM
01/18/23 07:50 PM
Posts: 2,938 A shed in England
Tig
A shed in England
I have run a co2 shift solenoid, (ACD?) on a B &M ratchet shifter since 2002. Flawless. Just make sure you have CO2! Pro Ratchet ??? Any pics ? TIA ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: A727Tflite]
#3114292
01/18/23 08:21 PM
01/18/23 08:21 PM
Posts: 9,897 MI, usa
dvw
MI, usa
What is the air and solenoid stuff you speak of? It must have something to do with that trans brake dohickey. Doug Do you need a reverse lockout with the push buttons? Suucchh.
[Re: Tig]
#3114353
01/18/23 11:36 PM
01/18/23 11:36 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have run a co2 shift solenoid, (ACD?) on a B &M ratchet shifter since 2002. Flawless. Just make sure you have CO2! Pro Ratchet ??? Any pics ? TIA I drilled a hole in the shifter arm for the wolinoid to connect to.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#3114412
01/19/23 08:56 AM
01/19/23 08:56 AM
Posts: 209 Finland
Hessu
Finland
[Re: gregsdart]
#3114414
01/19/23 09:11 AM
01/19/23 09:11 AM
Tig
A shed in England
I have run a co2 shift solenoid, (ACD?) on a B &M ratchet shifter since 2002. Flawless. Just make sure you have CO2! Pro Ratchet ??? Any pics ? TIA I drilled a hole in the shifter arm for the wolinoid to connect to. Thanks Guys ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: CMcAllister]
#3114471
01/19/23 12:31 PM
01/19/23 12:31 PM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
How is availability on those new right now? I may try to upsell my guy and put something decent in his cars. This will be the third one I have ordered in the last 6 months. All have come fairly quickly. But he is a one man shop these days and stays really busy, also working on some new features on the shifters. I would agree if you do not have an "inside track" to use a dealer. He is much quicker to respond to dealers than individuals.
[Re: Al_Alguire]
#3115068
01/21/23 10:46 AM
01/21/23 10:46 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Thanks for everyone's input..but am a little confused.... What is the actual shifter, air shifter components needed? ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) I looked at PPP website and went through the options and it seems to be about $1,100 for everything. Does that sound right?
