Modern seats in 73 Barracuda - what did you do? #3112256
01/15/23 09:02 PM
01/15/23 09:02 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
It’s gonna happen but not sure if recessing the seats into the floor would be a better option than sectioning the seat structure. I need about a 2” change in height.
What did you do ?
This is what I’m working with
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3112503
01/16/23 01:12 PM
01/16/23 01:12 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I'm surprised you have to lower the seats. Seems to me like most modern cars the seats are really close to the floor. Is you E body floor that much higher than my 68 B body floor? I put modern seats from a car in mine and we had to add height to them. If you need them to be lower, I'd vote for modifying the seat and not the car. Maybe you are using SUV or Truck seats?
You know who I am
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3112600
01/16/23 05:38 PM
01/16/23 05:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What did you do ?
What are they out of ?
Re: Modern seats in 73 Barracuda - what did you do? [Re: JohnRR] #3112622
01/16/23 06:52 PM
01/16/23 06:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Are they power? I ran mine all the way down. It helped. With the height but if I was tall. I'd lower them in the floor.
Re: Modern seats in 73 Barracuda - what did you do? [Re: Pool Fixer] #3112637
01/16/23 07:21 PM
01/16/23 07:21 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
These are out of a 2019 challenger and they are way higher than stock barracuda seats.
Re: Modern seats in 73 Barracuda - what did you do? [Re: JohnRR] #3112638
01/16/23 07:22 PM
01/16/23 07:22 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
What did you do ?
2019 challenger
Re: Modern seats in 73 Barracuda - what did you do? [Re: FastmOp] #3112639
01/16/23 07:23 PM
01/16/23 07:23 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
The drivers side is power but the passenger is manual. I’m only 5’8” and without mods they sit way up
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3112646
01/16/23 07:38 PM
01/16/23 07:38 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I cut about 2” out of the base and i also had to modify the floor some
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3112650
01/16/23 07:40 PM
01/16/23 07:40 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
After I shortened the base I bolted the flanges back to the slides and tack welded them onto the base, took it all apart and welded it up.
Passenger side is done
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3112872
01/17/23 01:44 PM
01/17/23 01:44 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I've heard that the new challenger seats require extensive modification to fit. The E body doesn't leave a lot of room under the steering wheel. A smaller wheel or tilt column can help. I went with seats from a 2006 Tiburon and they seem to fit really well and are very supportive. I'm 6' 2" 225lbs,
Re: Modern seats in 73 Barracuda - what did you do? [Re: gzig5] #3114222
01/18/23 04:18 PM
01/18/23 04:18 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
While I have not done this, take a look at mid 70's into the mid 80's Porsche 911 seats. They have a bit of an e-body vibe to them. I think these might make for a good swap.
1972 Dodge Challenger
Re: Modern seats in 73 Barracuda - what did you do? [Re: PLUM_72] #3114327
01/18/23 10:06 PM
01/18/23 10:06 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
They look good ! If I ditch these I have I’ll look into it
Re: Modern seats in 73 Barracuda - what did you do? [Re: PLUM_72] #3115458
01/22/23 03:50 PM
01/22/23 03:50 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Yeah, indeed, they look like a nice 'period-correct' upgrade!
I'm curious: what does a set of nicely finished seats like that cost these days?
Re: Modern seats in 73 Barracuda - what did you do? [Re: Diplomat360] #3115460
01/22/23 04:15 PM
01/22/23 04:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
https://www.carid.com/cipher/cipher...ts-universal-518035251.html?vehicle=7255
Re: Modern seats in 73 Barracuda - what did you do? [Re: lostdog] #3115785
01/23/23 07:47 PM
01/23/23 07:47 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I put Supra seats in my '74 Challenger. Had to fab the mounts to get them to sit level as the Toyota floor was flat and the Challenger floor does not. Used a piece of 1" square tube I welded to the seat track, added studs to it to align with the OEM holes in the floor pan. Bolted it in. All adjustments on it are manual, so no problem with wiring in electrical.
Re: Modern seats in 73 Barracuda - what did you do? [Re: TC@HP2] #3115791
01/23/23 08:07 PM
01/23/23 08:07 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I just put 2012 Chrysler 200 seats in my 65 B. Had to take just about 2" out of the seat mounting legs , but not all 4. I just put the seat uo in there sat in it and looked at it . Had the wife sit in and looked at it from out side. . before this I set the power settings in the middle . I cut an inch and then 2 inches . Felt it looked right. welded up some 1/8" plates for the bottom of the legs, marked out on the floor and welded some 3/16 plate to the floor at each leg. The front outer lined up with the factory brace and hole .
