Dual Blower Carbs- need provision for kickdown #3112255
01/15/23 08:54 PM
01/15/23 08:54 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Can someone show me what they did on their dual carb setup ?
This is what I have
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112258
01/15/23 09:06 PM
01/15/23 09:06 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Why would you need to have a functional to kick down with a Blower motor??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Dual Blower Carbs- need provision for kickdown [Re: W.I.N. Racing] #3112264
01/15/23 09:22 PM
01/15/23 09:22 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I probably don’t but I can’t leave the kickdown lever idle. What do you suggest I do ?
Re: Dual Blower Carbs- need provision for kickdown [Re: W.I.N. Racing] #3112273
01/15/23 09:45 PM
01/15/23 09:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A 727 relies on KD lever position to determine how much pressure to apply to clutches and bands.
If it's loose, full power will burn everything up. If set to max, every shift will spin the tires even on light shifts.
Boffin Emeritus
Re: Dual Blower Carbs- need provision for kickdown [Re: polyspheric] #3112275
01/15/23 09:48 PM
01/15/23 09:48 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yes, I understand that. Is the throttle position 1:1 with the kickdown ?
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112294
01/15/23 10:18 PM
01/15/23 10:18 PM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
manual valve body in trans
Re: Dual Blower Carbs- need provision for kickdown [Re: BlwnCrcab] #3112296
01/15/23 10:23 PM
01/15/23 10:23 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
That’s a possibility but also a last resort.
Re: Dual Blower Carbs- need provision for kickdown [Re: BlwnCrcab] #3112300
01/15/23 10:30 PM
01/15/23 10:30 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
This
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112301
01/15/23 10:35 PM
01/15/23 10:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
If you were to speed up the ratio by 1/2 and have the throttle just pull on an extension spring[low tension]I think you could do it if you get my idea.
Re: Dual Blower Carbs- need provision for kickdown [Re: Clanton] #3112302
01/15/23 10:42 PM
01/15/23 10:42 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I do and didn’t think about adding the spring but if you look at my levers I have already advanced the kickdown about 40% so I think adding a stiff spring would probably simplify it.
Re: Dual Blower Carbs- need provision for kickdown [Re: Clanton] #3112303
01/15/23 10:43 PM
01/15/23 10:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
With a blown motor you really need a manual valve body, good sprag, and a billet front drum or you are playing with fire.......
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112305
01/15/23 10:46 PM
01/15/23 10:46 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is only a throttle return for the most part.I don't see it controlling the trans at all.
Re: Dual Blower Carbs- need provision for kickdown [Re: Clanton] #3112312
01/15/23 11:05 PM
01/15/23 11:05 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I thought you were saying to add a spring inline with the kickdown cable which will actually work to solve over extension
Re: Dual Blower Carbs- need provision for kickdown [Re: slantzilla] #3112313
01/15/23 11:07 PM
01/15/23 11:07 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Transmission is built good. I’m trying to avoid adding more stuff ! Plus I believed I would have to get a different shifter with the manual valve body. I’ve had them in two other cars but that was a long time ago.
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112326
01/15/23 11:47 PM
01/15/23 11:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
50 years ago I drove a full manual (reverse) valve body on the street (E-booger and I converted the VB using the Chrysler kit). It was a misery to drive in traffic, even with 4.89 axle.
1 drop of rain makes the car undriveable. You can't shift unless the steering is centered, the car will climb a tree.
My 520 hp turbo Lexus's A340E auto trans has a spark retard during shifts to save the friction materials as OEM (25 years ago).
Boffin Emeritus
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112335
01/15/23 11:58 PM
01/15/23 11:58 PM
Why? shruggy
Real cars have to be manually shifted whistling grin
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112386
01/16/23 03:35 AM
01/16/23 03:35 AM
How does that work for you?
Those cables look like the cheaper ones I can't think of the correct name of them now blush
Re: Dual Blower Carbs- need provision for kickdown [Re: Cab_Burge] #3112397
01/16/23 07:32 AM
01/16/23 07:32 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
It’s a lokar kit and I hate them. They suck
Re: Dual Blower Carbs- need provision for kickdown [Re: lostdog] #3112402
01/16/23 07:44 AM
01/16/23 07:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't find street driving with a manual VB a problem it all. My car has 4.10s and an 8" converter. Once you are moving you just click the shifter twice and high is all you need until you stop again lol.
To go along with what you said I have never heard anything good about the Lokar kickdown cable kit.
68 Barracuda Formula S 340
Re: Dual Blower Carbs- need provision for kickdown [Re: Bad340fish] #3112405
01/16/23 08:42 AM
01/16/23 08:42 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I never had trouble either and I don’t quite follow what he was saying. I never used an aftermarket cable kit until this one and it blows my mind how many people suggested these lokar kits like they’re a good thing. They’re terrible! I toss that up to bandwagon commenters who never actually do anything but say a lot.
So about the kickdown - I know how I can make it work but came here to see if anyone had a better idea. Like I said before, I’m not opposed to manual valve body but I’m tired of adding this and that - just ready to drive it some.
